Good day gentlemen,
If I had record a piano part on my Korg D888 and I a wanna play with my guitar for rehursel, before I record my guitarpart I dont get anny sound from headfoon or speakers. Only when I Push the record button then I hear the guitar over the headfoon or speakers.
can you tell me what I did wrong? greetings Chris Pastijn.
Not a solution but a question that might get you closer to resolving this. Have you attempted to connect to any other computer with your D-888. Did this work?
When was the last time you changed the batteries? You may have gotten a pack of expired batteries the last time you replaced them. I suggest changing batteries.Jimmy
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
The hard drive has probably failed. In spite of it rotating, the head servo and electronics has to work. I would recommend testing the drive in a computer to see if it works. You will likely have to reformat it after if it does work. FIRST look for obvious things in the D888 like cable that is partially off or loose.
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
