Broderbund PrintMaster Platinum Version 18 Logo
Anonymous Posted on May 27, 2011
I've got Printmaster 12. I had vista before but changed it to windows 7. But now I can't seem to download it onto the computer again. Help
fanaudi
Level 3:
  • Broderbund Master 1,381 Answers
  • Posted on May 27, 2011
fanaudi
Broderbund Master
Level 3:
Answers
1381
Questions
0
Helped
294821
Points
4199
Hi dgk_builders
Your product is not compatible with Windows 7 .
Best regards ,
fanaudi .
Testimonial: "I don't know how you know this but I suppose you do. Thanks anyway"
  • fanaudi
    fanaudi May 27, 2011
    Thank you for your vote dgk_builders ! Your product is compatible up to Windows XP . You were lucky it worked with Vista . Please look here for the system requirements : http://www.avanquest.com/UK/software/pri...
    System Requirements
    Windows 95/98/ME/2000/XP
    Pentium 200 MHz processor (300 MHz for XP)
    64MB RAM/128MB RAM for XP
    Minimum 345MB hard disk space
    16-bit 800x600 colour screen
    4 speed CD-ROM drive
    Microsoft Internet Explorer 5.0 or higher and Internet service provider required for Internet access, online graphics, online projects, online greetings, website publishing and animated greetings
    Maybe you could try to run the program in Vista compatibility mode : right - click on the program icon on desktop and select " troubleshooting compatibility " . It might work . Good luck ! Best regards , fanaudi .
    Best regards ,
    Fanaudi ..
1helpful
3answers
Can you install Windows 7 on another machine and use the Product Key from another machine
Unfortunately that information you've got is not correct.
You may *not* do that. 1 license, 1 installation. The rule is quite clear. It's one copy (or one license) for each computer. There's nothing new here. This is exactly the same rule that's been in effect on every version of Windows starting at least with Windows 3.1.
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Will not install on windows 7 - cannot open all my saved files from old computer without installing PM gold 12.....
If it is not installing then it is probably not compatible with Vista or 7. Version 12 came out in 2004 and Vista didn't come out until 2006.
You can probably talk to their tech support and ask for sure but I'm sure they will tell you your version is to old for 7.
This is the only contact # I could find for them. 1-800-395-0277
Hope this helps.
1helpful
Hi I having Compaq Presario CQ40 and installed with Windows 7 Ultimate. Now I wish to change my OS to XP. Whether I can.. or otherwise?
I've tried looking at HP's website and saw that the only drivers available for download for this model of computer are for Vista or Windows 7 only.
It's still possible to put xp on this machine however you would have to look for the drivers manually. You would have to download them from the manufacturers website and the most rigorous part is to identify the model number and the manufacturer of the device built onto the motherboard of the laptop.
If you can live with it I do suggest you stick with windows 7. BUt if you really have to downgrade to XP better list the model numbers and the names of the device under device manager so you'd know which drivers to download.
Hope this helps!
I have Windows 7 and my Print Master 16 doesn't seem to work now
Printemaster 16 is not compatible with Windows Vista or Windows 7. You will need to upgrade the software.
1helpful
I want hp psc 1315 all-in-one printer scanner copier Software & Driver
Here are thedrivers . When you click on the links, give it a minute and they will'pop-up' on your screen. When you click 'Save' the driver package willbegin to download. OS Type Version Date Added File Size File Type Download Link (About) Windows XP Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows XP Printer Driver Download Windows 2000 Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows 2000 Printer Driver Download Windows XP 64-bit Driver 1.0 - Beta 2008-05-10 58.43 MB exe HP PSC 1315 Windows XP 64-bit Printer Driver Download Windows Vista 64-bit Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista 64-bit Printer Driver Download Windows Vista Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista Printer Driver Download Windows 7 Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 Printer Driver Download Windows 7 64-bit Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 64-bit Printer Driver Download ALTERNATIVEDOWNLOAD LOCATION.
Note: These are LARGE files and may take some time to download.
Save the driver file somewhere on your computer where you will be easily ableto find it, such as your desktop.
After downloading, go to the location where you saved the file and double clickon the file. Then simply follow the on-screen instructions for installing thedriver.
HPPSC 1315 Windows 7 Printer Driver Download
HPPSC 1315 Windows 7 64-bit Printer Driver Download
THE HP SOFTWARE IS AVAILABLE THROUGH YOUR OPERATING SYSTEM. ON WINDOWS CLICKSTART AND THEN SELECT THE WINDOWS FAX AND SCAN ICON.
Software: Download optionsand information Description: clip_image002.png This software installs a copy of the help files onto your computer. Install this software if you did not install from the CD or if you did not install the full featured version of the software. Do not install this software if the help files for the HP PSC 1315 are already installed on your computer.
To see if the help files are already installed on your computer, check the following destination:
Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help.
Windows Vista: On the Windows taskbar, click the Windows icon, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help. Details andspecifications File name: clip_image002.png MaggiMinus_Installer_24Nov08.exe [1/1, 24.91M] System requirements: clip_image002.png No additional prerequisites Released: clip_image002.png 2008-12-04 Version: clip_image002.png 1.1 Compatibility: clip_image002.png Microsoft Windows Vista, Microsoft Windows Vista (64-bit), Microsoft Windows XP 64-Bit Edition, Microsoft Windows XP Fix/Enhancement: clip_image002.png Updated the file to make the help files available from the Windows Start menu after installation is complete.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-66177-3&lc=en&dlc=en&cc=us&os=228&product=374568&sw_lang=&key=null&site=null
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_cd01d4e4178e5a11
2answers
Can i install the print master platinum 16 on my new computer with windows 7
ypu cannot use print master platinum 16 with windows 7 or for that matter vista
Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
2helpful
I purchased a printmaster platinum 12 in 2002 and loved it but now i am trying to download the software into a diffrent computer since out other computer crashed. i have my registration # but i can only...
I am guessing that your new computer has windows vista on it. That may be the reason Printmaster 12 will not install. Certain programs or their installations are not compatible with Vista.
I'm not sure what errors you are getting, and I am assuming you are running Windows Vista, so again I'm just guessing.
You could try to launch the setup program manually and using compatibility mode by following these steps:
1. Insert your installation disk.
2. Click the start button
3. Click on Computer
4. Right click on the drive containing your installation CD
5. Select Explore from the menu.
6. Find the Setup or Install file in the list.
7 Right click on it.
8. Select Properties.
9 Select the Compatibility tab at the top.
10. check "Run this program in compatibility mode for"
11. In the drop down menu select windows xp
12. check "disable visual themes"
13. Check "run this program as administrator" (if it is available)
14 click OK
15 now double click on the setup/install program.
I hope this solves your problem.
Thanks!
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
