20 Most Recent Broderbund American Greeting CreataCard Select 7 for PC Questions & Answers
I would buy another hard drive and mirror the hard drives. Then transfer the new hard drive to your computer. Mirroring will copy everything to the new drive
Broderbund... | Answered on Feb 24, 2018
Software issue. You need to do a complete uninstall of the program by going into the registry after you uninstall to remove any and all fragments left over by the normal uninstall. THEN, reinstall the program and see what happens.
Broderbund... | Answered on Aug 31, 2017
i hate Vista as well. i am trying to find a solution. my whole life over the past couple of years is wrapped up in the eventminder and fmnot32 files but after installing Creatacard on my machine with Vista, it will not recognize the files.
i open my address book, it's empty. i open my calendar it too is empty. how can i get this program to recognize the files i copied from the old machine? PLEASE HELP! i've tried everything including dragging them both over at the same time (file plus .BAK). i don't know what else to do.
Broderbund... | Answered on Mar 21, 2015
if it is a file drag the file to the page you want to use to e-mail
Broderbund... | Answered on Dec 22, 2014
Windows 8 doesn't run Outlook Express. If you are having problems with an old Windows XP program, you are out of luck. You will need to buy a newer version of the program if it is available. Don't worry about hating Win 8, you aren't alone. Everyone hates it, even Microsoft.
Broderbund... | Answered on Nov 05, 2014
Copying the files will not necessarily work, certain registry settings etc will not be established. you may try to install the program (CreataCard Gold 3) using compatibility mode and check if it can be installed. Access the link below and follow the steps to manually change the compatibility settings and install the program in compatibility mode and check if it helps. http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the above steps do not work I would suggest you to contact the program manufacturer to verify if they have any updates of fixes to install this application on Windows 7.
Broderbund... | Answered on May 11, 2013
rigth click on file creatcar....exe and in Tab "compatibily"
check the box Run this program in compatibility mode for ":
and choose Windows XP
Check box "Run this program as administrator"
Click OK
Double click in execute file Creat..EXE
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Broderbund... | Answered on Sep 20, 2011
i can email cards, but cards will not print.
Broderbund... | Answered on Jul 20, 2011
Hi there.
If you still have the cd installer, you can use this to install the program into the new computer otherwise, you really need to buy a new copy or get a similar freeware.
Please let me know if you need further assistance.
Thank you!
Broderbund... | Answered on Jul 16, 2011
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Broderbund... | Answered on Jun 26, 2011
This is an old piece of software. You can try right clicking the program icon, going to properties, going to compatibility and attempt to run it in Windows XP or Windows 98 compatibility modes. This may not work as the program is listed as incompatible with Windows Vista 64.
Please give me feedback for this answer, thanks.
Broderbund... | Answered on Mar 09, 2011
You can try to run the software in compatibility mode, which means that you can tell Windows 7 to run the software as if it was any previous version of Windows. To do this, browse to the setup.exe or install.exe file on the disk, right-click and select "Properties". Go to the "Compatibility" Tab, tick the box and select a previous version of Windows - the back of the CD Case will tell you which is the best version.
Broderbund... | Answered on Feb 28, 2011
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Broderbund... | Answered on Dec 05, 2010
well there is the Gold 8
Creatacard-Gold-8/dp/B00009APG9/ref=sr_1_1?ie=UTF8&s=software&qid=1288806903&sr=1-1">http://www.amazon.com/American-Greetings-Creatacard-Gold-8/dp/B00009APG9/ref=sr_1_1?ie=UTF8&s=software&qid=1288806903&sr=1-1
that atleast works with windows XP, and generally the programs that run on windows xp also run on windows 7 in my personal experience. But I can't guarantee it. windows 7 also has a compitibility mode that you can use to simulate windows XP or older.
You can install the version gold 7 and right click on its shortcut and select "Troubleshoot compatibility"
You can also manually try different compatibility settings by right clicking on the shortcut and selecting properties, then open the compatibility tab
Feel free to experiement and try all the possibilties offered on this page to get the program to work.
let me know if you have any further questions or if you require further assistance.
Ekse
Broderbund... | Answered on Nov 03, 2010
I have a solution for the american greetings card create a card, not being compatible with windows 7 if anybody is interested.
Unplug your sound from your speakers and it will work, dont ask me why, I did it by accident and it worked, plugged my speakers back in and it didnt
Broderbund... | Answered on Sep 21, 2010
Broderbund American Greeting CreataCard Select 7 for PC Logo
50 questions posted
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Broderbund Computers & Internet
Most Popular Question
older version
  • Computers & Internet
