20 Most Recent
Broderbund PrintMaster® Platinum 17 Full Version for PC Questions & Answers
I cannot open my printmaster
Sure - just use windows explorer and locate the documents you have in there. The files you created will have an identifier at the end such as " .doc " ".pdf" whatever.. Anyway, after finding them just transfer them over to a blank folder that you create making note of where you found them in the first place. Then uninstall the program, reinstall it and then put the saved files back into the same area you got them from originally. BTW, some programs when you uninstall them give you the option of not destroying files you created but with software I never take any chances!
Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
Converting files in printmaster to
I'm not familiar with the conversion in Printmaster, but here is a simple solution:
You can use Cute pdf writer.
Go to www.cutepdf.com and download the free utility. The nice thing about this is it will work as a "printer" for anything on your computer you need to print--in pdf format.
In essence, it becomes a printer--you choose to print whatever it is you normally print and chose cutepdf as the printer and it prompts you for a file name and there you go!
Art CD 1 is missing
Return to place to purchase as defective or contact broderbund for replacement cd at: www.broderbund.com
