20 Most Recent Broderbund Printmaster Silver 12.0 Questions & Answers
the code should be on the print master records
find the owners of print master and see if you can get in on an e-mail from them
Broderbund... | Answered on Oct 18, 2017
Hi Vivienne.
I have not used PM for many years (DOS 6 & Win 3.1 days), so i'll just make an educated guess what the cause could be:
Your newer version, Printmaster 12, may use a different file-extension, in other words, image file format, to the original PM8.
Explorer may show the extension if set up for this otherwise use the DOS method via a Notepad-written batch-file, PMext_CD.cmd.
Flash drive, aka Pendrive should be in your USB.
This saves the hassle of remembering your default documents path.
Of course, if you have a second HDD for storage, use it for the output result file.
Let's assume flash is drive F: and CD is drive D:
Open Notepad, presuming your OS is WIN xx.
@echo off
D:
CD\
cls
echo.
echo SEARCHING.....
Echo CD_DRIVE D FILES>>f:\pmfiles_all.txt
dir/a/s/b>>f:\pmfiles_all.txt
cls
color 4E
echo.
echo CD SEARCH DONE !!
pause
exit
save "all files" as PMext_CD.cmd
You can do the same for your PM12 HDD folder.
Batch-file name = PMext_HDD.cmd
Note: the PM pictures may be stored in a zipped or encrypted database, which will render the batch-file useless.
Failing that, try found out who makes PM from the CD sleeve, email them directly.
Hope this helps you.
Clive.
Broderbund... | Answered on Oct 13, 2017
I'm assuming you have just updated you operating system. If this is the case, that product is probably to old to run on your new operating system. you should consider buying the newer version of that program from this link:
Broderbund... | Answered on Jul 05, 2016
"Add printer" select your new one and set as default.
You can delete the old one from the printers folder.
Broderbund... | Answered on Mar 17, 2016
it may just not work on your computer. not all games or disks work on all computers
Broderbund... | Answered on Nov 03, 2012
Go to the print master home page or look for the question mark next to the exit x and see if the help pages come up, or just download from the printmaster home page
heres the link to printmaster home page
http://www.printmaster.com/
Broderbund... | Answered on Oct 31, 2011
Hi vegussec2000
If you are trying tu use it under W 7 , it's not compatible .
Best regards ,
fanaudi .
Broderbund... | Answered on Sep 12, 2011
I've had the same problem and was told it was because this edition of Printmaster is now out dated.
Broderbund... | Answered on Jul 13, 2011
yes, only because i'm totally awesome. ^_^
go here:
http://www.demonoid.com/files/?category=0&subcategory=All&quality=All&seeded=0&external=2&query=+PRINT+MASTER+PLATINUM+12&uid=0&sort=
Now this is version 16. but should do all you want. if you are not a member of demonoid.com it is free to do so. if registrations are closed use this invitation code to join :
HempKnight420Xdkh8uoyqgb1prclmijy9wubr8wfgfxk
Broderbund... | Answered on Jul 12, 2011
i would uninstall it then reboot your computer and then reinstall it. The software is fully working in vista and windows 7. So i am guessing there was a hiccup when copying files during install. I would also check drive c: or whatever drive you are installing it to , for errors
Broderbund... | Answered on Apr 09, 2011
Try to use USB CD ROM, or copy content of install disk on USB FLASH DRIVE.
Broderbund... | Answered on Mar 28, 2011
To use the discs you have to register. Your software has passed the free access period and to access those cds you need to register.
Broderbund... | Answered on Dec 26, 2010
go to contol panel,,do a system restore..go back in time before it was uninstalled
Broderbund... | Answered on Nov 01, 2010
you are gonna love this site. It is called www.emule.com you can down load anything, I mean anything for free, and your print master cd you should be able to get right away, see the way the site works is it grabs bits and pieces from owners arouond the world, so if you are looking for some high price software, you leave it running in the back grouund for as long as it takes, a day? 3 days? a couple hours, now this little old cd you need, you should be able to get it right away, also here is another idea, if the cd is cracked, but not cracked in half all the way, super glue it, but use very little as possible then clean cd to make sure there is no glue exposed on the cd surface, and it will work, let me know how this goes.
Broderbund... | Answered on Jun 28, 2010
If it will not install
  1. Find the Setup program.
  2. Right-click on the Setup program> Properties> Compatibility tab> select "Run this program in compatibility mode" check box.
  3. Select the operating system that the program ran on previously, and then click OK.
Also see
  • http://support.microsoft.com/kb/931361/en-us
Broderbund... | Answered on Apr 11, 2010
Broderbund Printmaster Silver 12.0 Logo
47 questions posted
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Broderbund Computers & Internet
Most Popular Question
printmaster 12 computer want
  • Computers & Internet
