You need to be more specific for me to give you my best answer but I'll try any ways. It would most likely be a ball joint making the clunking noise. It could also be your wheel bearing which is most likely causing the squeaking if the squeaking is only when the car is moving. If it squeaks all the time it would most likely be your serpentine belt. Lift your front driver tire off the ground and wiggle it to see if it has play. If it only has play up and down it's the lower ball joint. It's most likely both the lower ball joint and the wheel bearing. Unfortunately I can't give you more than "most likely" without knowing more.
Noise when you turn? cv axle
noise going stright AND sqeak- strut
