HP LaserJet 1020 Printer Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer hp 1020 in it when we print command of more then two paper the second paper jam (half inside and half out paper does not reach to Teflon part section . single paper printing is OK no pro. find. second paper prob.
Anonymous
Level 2:
Scholar:
  • Expert 157 Answers
  • Posted on May 23, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
157
Questions
0
Helped
47149
Points
496
Clean the Paper Feed Rollers with wet cloth.Then go to start-ControlPanel-Printers-select Hp1020 printer-properties-features-change the Paper Type as PLAIN PAPER.
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
1helpful
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
1020 hp printer problems
I would advise also opening the door on the back of the printer (if this printer has one), removing any paper trays and cartridges too. All of these can obscure places where paper can jam. Be thorough as even the tiniest scrap can cover a vital sensor.
Text and graphics not printing complitely Half Image and Half take printing from HP 1020 printer. If I give Print command only two or three line print come on paper after that four to five line black again...
Try another cartridge as it sounds like your drum is bad. If you measure the distance between the start of two sets of print I can tell you exactly what is wrong.
2answers
Paper has stuck between what to do
1.) First of all you need to power off the printer. 2.) Then pop the lid open, pull the toner out, and reach for the paper jammed and then pull it slowly. 3.) Replace the toner, cover lid and power on the printer.
2answers
Have paper out jam
hi,
maybe your separation pad is worn out that's why it can't pick up paper which causing the paper jam...
rey
3helpful
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Printer problem in hp laser jet printer 1020
Problem is you have paper jam!!! Seek for the paper inside the printer, pull out cartridge!!! when you do that, turn off printer and disconnect power cable for 1min. Pull back the cable, turn printer ON!!!
good luck!!!
1helpful
Hp laser jet 1020 paper jam and not printing... half paper inside of printer
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
k24674
Grand Canyon Tech
Grand Canyon Tech
