Televison & Video Logo
A
Anonymous Posted on May 09, 2011
Hello, We have just transferred our AWA DVD 5.1 Home Theatre System for improved sound to our television from our home theatre projector. I was wondering if there is any way of turning off the sleep mode which it goes into every 20 minutes unless you are playing a DVD.I have turned off the screen saver option thinking that may help but it hasn't. I'd appreciate your advise. The manual doesn't seem to mention an option to cancel the sleep mode. Thank you from L Jacob
Chi Chu
Level 3:
  • Televison & ... Master 8,457 Answers
  • Posted on May 09, 2011
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2823085
Points
26282
Just go into the device sleeper mode and now used the romte pushes the SLEEP button on the remote a few times to make sure the SLEEP mode timer it is to be turn off.This problems should be solved.
How do I attach sony w60b to sonny DAV-HDZ 284 DVD Home Theatre System?
You can use the Component Video, composite video or HDMI connections to connect the DVD home theatre system to the TV.
See the manuals on this site.
DVD Home Theater System
1helpful
Audiovox DVD Home Theatre System Sound Issues
check the audio settings make sure they match where you plugged the source. and if all of your sources run into the tv first you will need to have an audio out to the reciver
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
5helpful
2answers
How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Have pitcher no sound with my home theatre system
use an optical cable from your ps3 for sound to your amp, or use the red/white rca's on the cable the ps3 came with to go directly to your amp.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
