The error code is displayed when its beeping. I don't know the error code, so It can only be three things, Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below. Add up the lights that are on.
The Beeps are a beep code 4 means you have a ram read/write failure. Or a possible motherboard failure in that case you will need to contact Dell or replace it yourself.
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
If the keypad displays FC, that means that it is programmed to send alarms to a central station and a phone line isn't connected to the control panel. If you do not subscribe to monitoring services, it will have to be re-programmed. I can do that for you over the telephone if needed.
Thanx
Mark Garrett
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
