20 Most Recent Jenn-Air SCE30600 Slide-In Electric Kitchen Range Questions & Answers
Clock not bright
We rebuild a lot of this part for the dim display problem. This will save you some money!
fixyourboard.com/boards/71001799.html
11/1/2021 12:03:42 PM • Jenn-Air... • Answered on Nov 01, 2021
3answers
How do I obtain and replace the C3 capacitor
C3 capacitor rated for 68 µF- 35 Volts the closest radial capacitor from RadioShack is P/N 272-1015 (47µF-40 Volts). Pay attention to the position of the "white arrow" on the capacitor when replace. A little patience, a soldering iron and less than $1.50. Your range will be as good as new.Bonne Chance!
10/26/2021 8:00:57 PM • Jenn-Air... • Answered on Oct 26, 2021
Stove controls beeping and flashing "Probe"
Most likely oven sensor / probe is the problem. It can be tested with an ohm meter. Not sure about your model, but most should read around 1100 ohms at room temperature. If there's a tech sheet somewhere on your unit, it should tell you.
9/23/2017 10:06:05 PM • Jenn-Air... • Answered on Sep 23, 2017
Jenn-air vent fan will not turn off.
My Jenairre fan will not turn off. No function buttons work but the light on the oven.
1/11/2015 1:16:26 AM • Jenn-Air... • Answered on Jan 11, 2015
0answers
Jenn-Air oven shuts down after FC and F5 errors
Their was a good possibility that the solder could have been lifting of the contact points on the board, if the symptoms return i would check this, along with the said cleaning method :)
3/15/2014 10:50:08 PM • Jenn-Air... • Answered on Mar 15, 2014
0answers
0answers
I have a Jennair wall oven model WW30430PC. I need
I need to know the diameter of the base, without the flange. (the hole size)
11/4/2013 7:26:47 PM • Jenn-Air... • Answered on Nov 04, 2013
2answers
Kitchen range random chatter noise
could be clock motor or fan motor keeps running.
7/20/2013 9:29:26 PM • Jenn-Air... • Answered on Jul 20, 2013
I get an F2 error code and the broiler element will not shut off, even when oven is turned off! Had to flip circuit breaker to shut it down. What part do I need?
Follow the wires from the sensor to the control board and check the ohms there. It should be around 1050-1100 ohms, if the oven is at room temperature. If it is close to the correct ohms replace the control board. Probably a stuck relay on it.Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
2/23/2013 1:27:58 PM • Jenn-Air... • Answered on Feb 23, 2013
Oven fan
you dont fix it its working fine, the fan comes on at a predetermined temp and doesnt shut off unit l cools to a certain temp as well , its to protect electrical components from overheating. every new stove does it has to happen!!
2/5/2012 2:52:38 PM • Jenn-Air... • Answered on Feb 05, 2012
0answers
Hello again a just posted
We went through all of your wiring and discovered a few loose connections which we tightened and tested. Thank you Ken for being such a great help. Remember WE Can make work, even if we have to invent or own test equipment as the 110 v bulb and socket wires:)
8/16/2011 8:22:38 PM • Jenn-Air... • Answered on Aug 16, 2011
My JENN-AIR oven will only heat to 250 degrees.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
7/6/2011 2:18:32 AM • Jenn-Air... • Answered on Jul 06, 2011
What does it mean when
Fc denotes communication trouble between boards.
5/8/2011 9:56:39 PM • Jenn-Air... • Answered on May 08, 2011
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
109 questions posted
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Kitchen Ranges
Most Popular Question
obtain replace c3 capacitor
  • Kitchen Ranges
