Hi Scott,
Since the generator starts but there is no power to the control board, there is an electrical problem inside the generator.
First check the circuit breaker at the back of your generator. If the breaker is on, then your generator is in serious trouble.
Call a repairman, but also keep in mind you may need a new generator.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Hi and welcome to FixYa, I am Kelly. My research has the model number of your generator engine as GT-990 Is your generator model number 05506? Or something other than that like 5785 or 5744? I found the service manual for the engine already. I really need to know what your genrator model number is please. 05506 whisper series, 5785 and 5744 are the Guardian series by GENERAC.
Kelly
Try disconnecting the three connectors P1-J1, P2-J2 and P3/J3 from the controller and reconnecting same.
The serivce manual is here:
http://www.zabatt.com/Generators/product...
It does little to help with you no display problem
As a tech I would be locating both F1 and F2 fuses. After verification of the fuses next sterp would be to locate the main board transformer.
tranformer checks
Pin 1 & Pin 2 are the primary winding. Check for resistance across P 1 and P2
the rest of the windings can be laid out in 2 ways one is individual windings and the other is a string / tap winding
Individual windings
3 - 4 resistance
5 - 6 resistance
7 - 8 resistance
String tap winding
Pin 3 to pins 4 5 6 7 and 8 for resistance.
Somtimes you have to read power off of each transformer winding
the output power is usually 24 VAC or less
the most common outputs are 3.3V, 5V 15V and 24 VAC
reading output power on the main PCB pin 4, pin 6 and pin 8 for AC voltage.
If you have no voltage the Main Board transformenr has failed.
Main board transformers fail mainly due to other component failures on and off the board, and corrosion on the board or at the connectors. Finding the failed part is often very difficult with a failed main board. You end up having to read out each and every circuit connecting to the main board! Otherwise you can install a new board and have it fail in seconds!
I forgot to ask which controller you have?
R-100
R-200 or R200A
Kelly
I am pretty sure this is your controller:
http://www.guardiangenerators.com/Public...
Again very little help with no display!
Kelly
Check to see if you have 12 VDC across the red and black wires of the control panel. During the engine start-up and run, +12 volts DC is applied to the control module via the red (+ positive) and black (- negative) wires. The voltage from the main engine control latch/crank PCB Wire 14 (run circuit) powers up the control module for governor system operation. The control module receives a speed "sensing" signal from AC output frequency via the two (2) blue wires. The control module sends variable signals to the stepper motor via the orange, yellow, brown and black wires to position the stepper motor and throttle linkage to obtain a steady 50 or 60 Hz. (selectable on
the control module frequency switch)
Also check that the black wire is actually providing a ground.
Kelly
Perform this test also: TEST 18 - CHECK DC VOLTS AT TERMINAL 14 OF TB1 DISCUSSION: This test will determine if control board action is delivering battery voltage to the Wire 14 circuit. Wire 14 circuit voltage is required to (a) power the engine ignition system and (b) open the fuel solenoid. Terminal board TB1 is housed in the generator control console. See "Control Console Components" in Section 4.1). PROCEDURE: 1. Use a DC voltmeter (or VOM) to check for battery voltage at Terminal 14 of terminal board TB1. 2. Connect the positive (+) meter test lead to Terminal 14, the common (-) test lead to Terminal 0 (ground). 3. Set the AUTO-OFF-MANUAL switch to MANUAL. The meter should indicate battery voltage. RESULTS: 1. If battery voltage is not indicated, test Wire 14 between terminal board TB1 and the control board for an open condition. a. If Wire 14 is good, replace the control board. b. If Wire 14 is bad, repair, reconnect or
replace as necessary.
I think this test will pass as you said it works in manual.
Kelly
Your response must have gone to another expert because I had to dig through my site historical files to see your response. Anyway as far as the intensity issue the onlything I can tell you is to look on the back of the control display module. Usually thee is ONE tiny screw for an intensity adjustment. What ever you do please do NOT tap on this module with any force. You can cause more LED problems. (don't ask how I know!) I can not remember the number of the potentiometer that is to be adjusted but as I said there is usually only one one the very back of the module. I can't remember if you have to unmount the display or not to gain access either. Make sure you mark the potentiometer where you started because some of these have that same screw that adjusts current transformer sensitivity and you end up having a generator that wil not start will a loss of utility power or... will not auto switch back to utility power.
Kelly
Kelly
The generator is a 5744 model.
thanks
Kelly
Checked items suggested. Pulled battery & charged.
Generator starts in both automatic & manual modes.
Have a very faint display on the controller. ( have to look at the right angle to see it,)
Battery voltage shows 13.4.
Generator & battery are 1 1/2 years old.
Thoughts on increasing display?
thanks
My center display just stopped working. The screen is black.
Replaced the battery (to 70amp). Works fine however instrument panel which should show automatic gear selected next to odometer now shows a B with a line through it. Also keys now dont work on the plip buttons. Advice please!
POPPING NOISE WHEN TURNING WHEELS
remote control only works sometimes. Bought a new visio remote, does the same thing.
i have a zanussi electrolux essential 1200 machine. it doesn't start.... After i choose a program i can hear a clicking noise and then start/ pause button starts to flash green.
I done this:
"Switch the appliance on, any programme.
Close the door.
Wait 1 minute.
Press and hold the start pause button and the button immediately to the left of it together."
13 reds and 4 green flashes.
What is the likely cause ?
please provide checklist of fuses or relays for this problem
failed obd test
during set up tv continually going through Auto Scan
water deposit light flashing even though its not full
special kit for high altitude
Automatic trans; high pitch whine just prior to shifting to a higher gear.
how to change window regulator on 2001 chevy impala
2005 Ford Explorer Sport Trac - Drivers power seat and all power windows including rear window stopped working. Suspect a fuse or breaker or harness. Which fuse?
red light appears suddenly on touchpad and then cursor is locked, will not move
I'm having trouble getting to my acct. Have to go thru many screens & often never get to my acct. NOT happy with the new format.
how do you get no green pipes on flappy bird
my 46 inch samsung tv is darker on the right side of the screen then the left side. how do i fix it?
outer clutch plate hits inside of outter primary when you pull in the clutch
the tv picture was fine a few days ago i tried to make it brighter and now its seems to be dark looking i set it to factory reset but its still dark
3.3 L v6 SE
reset time on my timex ironman watch
where do I add transmission fluid in my 96 impala
it stuck shut
gta v cheatcodes
3 in 1, 42 inch deck on yard king riding mower made by swisher, unable to find mulch kit.model 425648xo6a
how to connect a coby cs-mp77 to my tv
Key fobs don't need a new battery
when I enable mac filtering I can not access the wifi with our mac book pro laptop. When I disable mac filtering it will work. I would prefer to use the mac filtering option on the router to block my neighbors which used my wifi before I turned on mac filtering and blocked them. any suggestions?
When I hit print, nothing comes out. A blue wavy line appears on the LED screen, but no error message pops up on my MAC.
The light on the dash with clock fan radio has been flickering it doesn't stop on anything and just goes into flicker mode
where to position switch on normal driving
When it is dark outside head lights will not come on automatically or by pulling the switch.
brake light fuse keeps blowing
i have to fill my overflow at least once a week and i have some liquid comeing out tailpipe no white smoke or nothing no over heating replced radiator and thermostat no white stuff on oil dip stick no water in oil just has me puzzled
where can i get the fuse box diagram for a 99 dodge durango 5.9 l
right rear indicator bulb blown how do i open it
