Refrigerators Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Two door fridge. The Lower portion is the deep freezer and it is working fine. The top portion is { the regular/general part of the fridge }not working but the lights are on. we have checked the knob & its setting is also ok. Haier ref :306HP BMR bought on 6th June 2008. @ Devi International. Bangalore.
Anonymous
Level 3:
  • Haier Master 43,501 Answers
  • Posted on Apr 23, 2011
Anonymous
Haier Master
Level 3:
Answers
43501
Questions
0
Helped
10845492
Points
101584
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
2answers
I have a problem with a bush fridge. Its brand new and water keeps collecting on the top shelf at the back of the fridge and ice droplets form at the top at the back of the fridge
Please ensure that the fridge door is completely closed when you attempt to shut it. Please check from any leaks from the freezer portion of the fridge to the non-freezer portion. Try to temporarily lower the freezer temperature by 20 degrees and check what affects it has on the non-freezer portion.
Thank you.
Our 10 year old samsung rfg298aapn refrigerator freezer started not fully freezing all the time. mainly things like ice cream/popsicles getting soft.
I have never owned a fridge freezer so have no experience to draw on apart from a sketchy knowledge of the principles involved.
I just wanted to mention that food remaining frozen at -2 C or even -6 C doesn't mean the food will remain safe to eat indefinitely, in fact the safe life of food at those temperatures will be about the same as in the freezer compartment of the old fashioned fridge - a matter of a few weeks to a couple of months.
The safe and almost indefinite storage of freezer food requires temperature of -25/-27 C
I suggest you obtain service for your fridge freezer...
Fan in Freezer portion not running, compressor works
The door switch, some fridges run the fan on door closed only.
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Fridge portion no working
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
1helpful
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
2answers
1helpful
2answers
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
