D-Link DIR-615 Wireless Router Logo
Posted on Apr 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have followed instructions (several times) to connect my dlink router dir-615 and once I unplug the ethernet cable and attach to dlink (blue slot 1) and plug in power to the router....it no longer can access internet. service provider is comcast.
Clive Gray
Level 3:
Genius:
  • Master 1,479 Answers
  • Posted on Apr 17, 2011
Clive Gray
Master
Level 3:
Genius:
Answers
1479
Questions
Helped
291317
Points
4728
The blue socket should be connected to your modem, it is this modem that supplies the internet for your router to distribute to your computers so if you disconnect the blue cable from your router you are disconnecting the internet
My new roku 2 will not connect to internet my wireless router is a dlink dir 615 and I know I am using the correct password
Upgrade to an ethernet cable connection between the router and the Roku. There is a slot on the side of the Roku box for it. This should enable you to enter the password- and give you a more stable streaming experience
My instruction manual is in Chinese, i am using a mac and i cannot connect wirelessly to the internet, I have a DIR-605 router.
well here is a link to obtain the manual http://www.dlink.com/products/?pid=DIR-615
you need to select Support Resources Tab and choose the revision type you have. then you select product manual. One example is this one "DIR-615 no rev. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
My dlink router dir-600 was purchased only last month. It was all working well until 3 days ago...the light in wireless icon and other LAN all stopped. Only power and Globe lights were Orange... no...
If you have ethernet cable, plug one end of cable into in available slot of router (LAN) and other end ont your laptop to see if you can get out Internet that way. If not, turn off you router, wait for a minute and turn it back on. If it works after the reboot, try wireless again to see if it works. Most of time, router just needs to be rebooted.
thanks
How do I set encryption/password on DIR-615// Many Thanks, Steve Pfeiffer tunemxrgmail.com
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
DIR-615 wireless router not installing
You setup the router with the Ethernet cable always plugged in.. UNTIL you are finished configuring through the Ethernet cable via your browser. Once WiFi SSID & passwords WEP/WAP has been finished, AND you had another WiFi card in that PC the Ethernet cable was also connected to... well, THEN, I guess THEN, you may be able to disconnect the router from PC & then connect it again Wirelessly. But whats the point? But until then you won't find your router ON the Ethernet port, it would then be trough the WiFi adapter.. and that would have to be activated to work. Hope this clears things up
2answers
I FORGOT PASSWORD FOR DLINK-DIR 615 AS IT NEEDS TO CONNECT TO LAPTOP ..HOW COULD I FIND IT?? I TRIED TO LOG IN AS IT REFUSED.. THANK YOU
Use an Ethernet cable to connect the laptop to the router.
Access the router's built-in web-interface, and run the "Wireless Networking Setup Wizard", and choose a password.
1helpful
Need security encryption code for dir 615
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You will need to check the wireless settings of the router .
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Dlink wireless windows vista
Connect an Ethernet cable to one of the 'LAN' ports on the router and to the network-port on your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER.
You should get output like:
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 124.268.336.448
Default Gateway . . . . . . . . . : 123.456.789.0
Start Internet Explorer.
Type: http://123.456.789.0
to connect to the web-server "inside" the router.
Run the "wireless network setup wizard" to configure the router
with an SSID and a password.
Save and reboot the router.
Disconnect the Ethernet cable.
Your computer should report "Wireless Networks are available".
Choose your network, and enter the password for the network.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
