Lexmark X5150 All-In-One InkJet Printer Logo
Posted on Apr 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink cartridge error 50c whats up with that - Lexmark X5150 All-In-One InkJet Printer
  • Official Brand Answer 3,344 Answers
  • Posted on Apr 18, 2011
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923817
Points
5508
This article in the Lexmark website will help you identify and resolve your 50c cartridge error: Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen.
What is Cartridge Error 50C?
Error message 50C in the Dell A940 All-in-one means that the ink cartridge(s) are seated improperly.
Here are basic steps to try that should resolve the issue:
1. Reseat the Ink Cartridges.
2. Unplug the printer from the back, clean the contacts and the put back the connection.
3. Verify whether the Ink Cartridges are DELL Branded.
4. Try Cartridges Individually.
3helpful
Error 50c
Hi there Error 50c
Gave it a go it may work for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
color cartridge.
My all-in-one printer A940 reads "error 50c" i have replaced both ink cartages what could b the problem?
Hi there Error 50c
color cartridge.
2helpful
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
2helpful
My A940 All-in-One shows a Cartridge error 50C and also shows that the colour cartridge is missing when it is not can you please help tried looking through manual but cannot find what a 50C error is please...
Hi there Error 50c
All the best of luck
color cartridge.
1helpful
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
color cartridge.
Error 50c Using real Dell carts Tried reinstalling drivers still
Hi there Error 50c
Here we go try this out.
color cartridge.
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
12helpful
3answers
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
