You should have a template in the kit for this. The web site will also have detail specifications.
Short of that (and I've been there) use a piece of cardboard. Trace the outside edge. Now make in inner circle the width of the flange area. Cut out the remaining center. Align it to the shaft on the wall and mark your cut line. Some of these have a single screw that attach the cover to the hardware in the back. Being a thin wall you may need to set back the plumbing tree to get the cover all the way in. If you are soldering the fittings be sure to remove the nylon sleeve first as the heat can damage it.
