20 Most Recent Delta Faucet #RP320 Divert Assembly Questions & Answers
How do i remove
it just pulls out might be stuck alittle put it will come out
9/25/2011 1:37:04 AM • Delta Faucet... • Answered on Sep 25, 2011
I have an older delta faucet. Sprayer does not work well.
i believe the faucet shaft,..they usually are on delta models i've worked on,........your best to get a full rebuild kit for this and do the whole thing when you've got it down,.....good luck, cracklin joe
1/10/2010 1:52:32 AM • Delta Faucet... • Answered on Jan 10, 2010
The spout in my bathroom is dripping is this
It is possible to fix this yourself, but realize that the valve on the tub/shower is holding back huge amounts of water under high pressure. Make sure you know how to shut off the water to the house, and make sure you do it. You'll need to get the proper parts at a local hardware store and have good understanding of what you're doing. Try this link: http://www.rd.com/how-to-repair-a-leaking-tub-faucet/article17727.html
12/31/2009 10:03:55 AM • Delta Faucet... • Answered on Dec 31, 2009
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
6/12/2009 10:03:21 PM • Delta Faucet... • Answered on Jun 12, 2009
I just moved into a new place with Delta shower
On the bottom of your tub faucet is a ringed part that is about a 1/2 wide. Turn the water on, grasp that firmly in your fingers, and pull it straight down. Your faucet should come on.
Sirwriter
5/21/2009 12:55:48 PM • Delta Faucet... • Answered on May 21, 2009
Delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
4/9/2009 4:48:24 AM • Delta Faucet... • Answered on Apr 09, 2009
How to remove stuck cap for delta single handle faucet
Take a rag and put over nut then tap all-around nut. Then use your hand to try and unscrew. A strap wrench is the best tool for taking these off. I have been to so many of these where the homeowners have used channel locks or pipe wrenches and scarred up nut or broken off copper tubes. They seem amazed when i tap it a few times and remove it with my hands. Channel locks and pipe wrenches actually cause the nut to bind when using this much force. Make sure you loosen the plastic retainer on top of the nut first.For more details about single faucet repair
8/24/2021 4:21:14 AM • Delta Faucet... • Answered on Aug 24, 2021
The single handle Delta kitchen
remove the handle that turns water on and off , usually an allen wrench lift and swing back and forth at the same time. the spigot should come off. replace o rings lubricate with silicone grease reinstall spigot and handle
11/16/2017 4:52:11 PM • Delta Faucet... • Answered on Nov 16, 2017
2answers
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
1/26/2016 4:43:03 PM • Delta Faucet... • Answered on Jan 26, 2016
2answers
Delta 400-DST Single Handle Kitchen Faucet Spigot Drips
I've installed quite a few of these from the big box stores that leak. There are 2 rubber pieces inside the valve body that act as seats. The seats are what turn the water on and off as you move the handle. These rubbers need to be replaced. You can buy a delta repair kit, which will contain these parts. Where the faucet is new, it might be easier to bring it back
6/16/2014 5:01:02 PM • Delta Faucet... • Answered on Jun 16, 2014
Water will not flow through the bathroom faucet
It probably is a clogged aerator. The small piece, right where the water comes out, unscrews. There is a screen behind it the often collects dirt and minerals. Clean that off and try it again
4/29/2014 1:03:55 AM • Delta Faucet... • Answered on Apr 29, 2014
Wanter not going throught the bathroom faucet
Unscrew and clean aerator.
1/18/2014 1:31:56 AM • Delta Faucet... • Answered on Jan 18, 2014
What causes black **** to build up in the water faucets and the dishwasher and everywhere water comes into the house? We have had the water company here soooooo many times and now they are saying they
The cause is Hydrogen Sulfide either in the wells they are pumping from or due to bacteria. Do you also have a 'rotten egg' odor? High concentrations of this gas can be deadly. You should get the yearly report the water company must produce on the composition of your water and analyze it. You may want to have the water in your home testes to see if it has the same percentage of H2S that they are reporting. You can remove some of it by Carbon Filtration but you would have to speak to a local water treatment company.
11/15/2013 1:11:12 AM • Delta Faucet... • Answered on Nov 15, 2013
When I first turn on the hot water to my shower there is a loud noise, then it goes away. Why is this happening?
It could be lime/ calcium deposits in the shower head. Soak shower head in clr and it should be good to go
2/28/2013 5:50:41 AM • Delta Faucet... • Answered on Feb 28, 2013
Base of single handle kitchen faucet is loose where it sits on the counter
there should be 2 plastic nuts under the sink that hold the fixture tight to the sink. if they are tight allready try to install washers and see if that helps. right is tight. left is loose.
6/8/2012 12:18:12 PM • Delta Faucet... • Answered on Jun 08, 2012
Low pressure and have take head apart not plugged
Modern low flow plumbing devices reduce water flow by using smaller passages inside the unit. The downside of this conservation is that appliances are more easily clogged by debris that may be in the supply lines. Frequently it gets stuck in the cartridge. I have even found it in the supply line connections.
12/31/2011 10:32:17 PM • Delta Faucet... • Answered on Dec 31, 2011
Our RSVP faucet, 6590-PC is leaking. We do not
Just faucets in general I look underneath..they are often attached W/ nuts ..
4/7/2011 4:39:08 PM • Delta Faucet... • Answered on Apr 07, 2011
Hi...I have my faucet apart
They are flared out a little to create a good seal so if you use some vegie oil to lube them up some they will push right in. just be **** and patient.
3/6/2011 9:05:32 PM • Delta Faucet... • Answered on Mar 06, 2011
Delta 476 faucet is leaking.
http://www.faucetdirect.com/mediabase/specifications/476install_051710.pdf
Here is where to find the manual for your faucet. The only tools you should need are a pair of slip-joint pliars for the main ring and the hex key tool that came with the replacement parts. Remove the handle by loosening the hex screw on the underside. Make sure to turn off the water before you go any further and you will need to turn off both hot and cold.
Remove the dome-shaped cover either by hand or with some pliars.
Pull out the ball with the stem in it and underneath there will be two rubber washers with two springs underneath. Remove the washers and springs and put the new ones in. Put in the new stem (ball with stem) taking care to line up the slot in the side with the nub inside the base. Replace the round washer on top with the triangle hole in it and put the dome shaped cover back on.
Before turning the water on, use the back side of the hex-key tool to tighten the nylon ring that screws down into the dome shaped cover. Put the handle back on and try the faucet, if it moves too hard, loosen the nylon screw a bit, if too loose then tighten it. Once it "feels right" you can reattach the handle and turn the water back on.
I suggest turning on the water slowly and look for leaks. Not as difficult as it sounds.
2/24/2011 11:11:16 PM • Delta Faucet... • Answered on Feb 24, 2011
Delta Faucet #RP320 Divert Assembly Logo
11 questions posted
Top Delta Faucet Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Delta Faucet Plumbing
Most Popular Question
remove
  • Plumbing
