Dell A525 Computer Speakers Logo
Anonymous Posted on Apr 04, 2011
No sound and have latest driver update also my sound card is good (No X)
  • Anonymous Apr 04, 2011
    First, Thank You for trying to help me out. Following is results:
    No yellow question mark in sound, video and game controllers
    Have the Latest Driver
    Opened Computer and cleared any dust
    I do not have a Sounds and Audio in Control Panel. I do have sound which displays SigmaTel High Definition Audio CODEC with working. When I select the speaker setup and test Window Appears with FAILED TO PLAY TEST TONE.
    Any other suggestions. AGAIN THANK YOU
  • Anonymous Apr 05, 2011
    Vista. How do I uninstall my sound card? How do I find my sound Card? All I have listed is sound driver.
Brian Sullivan
Level 3:
  • Dell Master 27,725 Answers
  • Posted on Apr 04, 2011
Brian Sullivan
Dell Master
Level 3:
Answers
27725
Questions
Helped
5670455
Points
79191
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
  • Brian Sullivan
    Brian Sullivan Apr 04, 2011
    you might have to uninstall the sound card then restart your computer then reinstall the sound card and its drivers
    what operating system are you using?
  • Brian Sullivan
    Brian Sullivan Apr 05, 2011
    click start control panel administrive tools computer management device manager scroll to sound,video and game controllers +or select to expand right click on the expanded audio you should have options to update driver sftware disable uninstall scan for hardware changes and properties
Is there a driver I can download from somewhere for the Harman Kardon computer speakers system Model HK695-01?
Speakers themselves don't need drivers. The sound card however does. you will either have a sound card in your motherboard or one plugged in on your motherboard. 9 times out of 10 checking the optional section of windows update will contain your sound drivers needed. If it does tick it to install them. If not you need to find either your motherbaord manufacturer and model or sound card manufactorer and model, go to their website and download the latest drivers.
Good luck.
My NEC computer sound did not com on windows 7
Try installing the latest driver. If your computer used to work great (sound), then updating the sound driver should do the thing. You can find the driver in the website of the computer's manufacturer. However, if you want to make sure that you can get the correct driver, then you can use RadarSync to scan your computer for outdated drivers. The software will then automatically search for the latest updates. You can Google for the suggested drivers and install or you can buy the license to let the software update all automatically.
I hope this helps!
David
How can i update my Toshiba Satellite A80-127 sound card online?
you can update.. or check for updates for the drivers for your sound card by going to www.toshiba.com and downloading and installing that latest version of drivers for your specific system.
3helpful
3answers
There is no sound from my computer when i troubleshoot this was the response: DirectSound Driver output v2.2.10 error Error code : 88780078. what will i do so i can have a sound coming from my computer?
hi,
you need to update the drivers of sound card, if no update kindly reinstall the sound card drivers and download latest directx.
http://microsoft.com/directx
I can't hear clear sound from my pc and the driver from the board cd is not properly installed. I have tried to update the driver, yet the problem exists.
Unistall completely the sound driver software. Go to manufacturer website and find the latest driver that is supported by your motherboard. Good Luck
No audio
if your pc does not have audio there are usally only two reasons 1) bad sound driver 2) BAD sound card. youcan go to the manufacturers web site to download the latest driver for your machine if that doesnt work try windows update. Sometimes Windows update has hardware updates.If that fails buy a new sound card.
1helpful
3answers
My sound card don't work
Try reinstalling audio adapter driver.
If you have misplaced original driver disk, Gateway drivers are available from: Gateway Support - Drivers, Software and Firmware Updates
Notebook onboard memory card drivers
Issues relating to msgrv32 Second, verify that your sound card has the latest drivers and/or updates installed from the computer or motherboard manufacturer (if onboard sound).
Computer Video Card Support and Help Drivers, Video card drivers and manufacturer listing. ... CH000193, Issues with adding new video card to computer that has on-board video.
Good Luck, Please dont for get to Vote,Thank You.
2answers
Regarding sound problem in my pc
is this xp if so go to start/run/type dxdiag then click the "sound" tab then test the sound to the left you will see"hardware acceleration bring that down a notch and try that also you may have to update your driver for the sound card you have.Sometimes when you install something you loose the sound.Also try system restore
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
