20 Most Recent Dell HK395 Computer Speakers Questions & Answers
5answers
HK395 Speakers/Subwoofer Cable
6/4/2019 10:56:51 PM • Dell HK395... • Answered on Jun 04, 2019
2answers
I need a new HK395
Try http://www.redplanettrading.com/search.php?mode=search&page=1. They have the HK395 model for a pretty good deal and they might be willing to cut you a deal for just the part.
11/30/2017 1:07:12 AM • Dell HK395... • Answered on Nov 30, 2017
Dell HK 395 Speaker System - Need Circuit Diagram Download
1.  Check the orange multi-pin connector the sufwoofer for a broken or bent pin.  If there is a broken pin you can bypass it by cutting open the cable jacket and tap onto the affected wire with a 6 inch or so jumper, and then attach a jumper to the appropriate point inside the subwoofer.  Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
2.  Try wiggling and rapidly rotating the volume control.   There are reports this control may become a problem as it ages.
3. I haven't been able to find a schematic.  My only recourse was to google the output amp and the 2 op-amp packages for data sheets.  They are readily on the internet.  Then I laboriously traced out the stereo paths.  I found that red and black fine tip felt pens were helpful in marking out the signal paths through the circuit boards.
3/6/2015 9:15:48 PM • Dell HK395... • Answered on Mar 06, 2015
The limo k connector is missing, so how do i connect the wires? and where to connect to it?
50f75bc6-abfa-4d5f-8a4b-7eabf7fe16ab.jpg a18494dc-05b7-4aaa-8fa3-8da51aa2053e.jpg Is this the connector your questioning?
6/26/2014 3:27:31 AM • Dell HK395... • Answered on Jun 26, 2014
0answers
HK 395
Be the first to answer 6/21/2014 9:38:25 PM • Dell HK395... • Posted on Jun 21, 2014Be the first to answer
Lost controller. how to use or by pass on off swith
Solder a jumper wire across the back of the switch, this will bypass the switch and the speakers will always be turned on. Turn off the speakers by unplugging the power cord, or with the switch on the surge protector that I hope you have.
4/22/2014 1:39:16 AM • Dell HK395... • Answered on Apr 22, 2014
Static on HK395 satalite speakers
It might be beacuse of some sort of wireless interference like a cell phone.
3/17/2014 9:26:19 PM • Dell HK395... • Answered on Mar 17, 2014
0answers
Can blown capacitors lead to speakers emmiting crackling, static noice
hi G, Yes it is and faulty ics also..... regards, nuwan
1/21/2014 11:38:16 PM • Dell HK395... • Answered on Jan 21, 2014
Crackling static noice
Hi Roovejet. The capacitor 104 is 0.1uf ceramic has no reading with analogue multimeter in any range of ohms scale. if it read any of ohms value ,it is bad. please check the large electrolytic capacitors too and loose connection for the board and.if you have volume controllers clean it with alcohol or contact cleaners. if your device is older than 5 years it is time to change all the electrolytic capacitors.its sound like foolish but it brings new life and same quality when your buying time to the sound system. regards. nuwan
1/20/2014 8:38:21 AM • Dell HK395... • Answered on Jan 20, 2014
Blinking green light with no sound
Control panel, sound, be sure that all boxes are have not been muted.
1/7/2014 7:56:41 AM • Dell HK395... • Answered on Jan 07, 2014
Broken orange plug on right speaker going into subwoofer
Other posters to this forum have said this connector is available at Radio Shack.  If you can't find a connector here is a workaround that will do the job:
If there is a broken pin you can bypass it by cutting open the cable jacket and delicately soldering a 6 inch or so jumper onto the affected wire, and then  solder a jumper to the appropriate point inside the subwoofer. Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
11/26/2013 4:43:53 AM • Dell HK395... • Answered on Nov 26, 2013
2answers
Where can i buy the cable to connect the
11/25/2013 11:47:43 PM • Dell HK395... • Answered on Nov 25, 2013
Hi. need a replacement tweeter for one of the
Try http://www.redplanettrading.com/search.php?mode=search&page=1.They're reasonable and might be willing to give you a deal for just the part.
11/25/2013 11:44:51 PM • Dell HK395... • Answered on Nov 25, 2013
3answers
Left speaker not working
Hi Dellhelp, this sounds like a defective volume switch to me. If you're handy with tools and have a soldering iron you can probably pick up a suitable replacement switch for $5 and spend 30 minutes installing it. Or for around $20 on Ebay you could buy another working unit. I wouldn't really recommend spending much time or money trying to fix them and if you do buy another set you can keep your old ones for parts :) http://search.ebay.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Fws%2F&fkr=1&from=R8&satitle=hk395+speakers&category0=&submitSearch=Search Let us know if you need more help and don't forget to rate the posting.
10/18/2013 12:41:28 AM • Dell HK395... • Answered on Oct 18, 2013
I have harman karden subwoofer but i dont have any
hmmm....does the subwoofer have any controls on it or are the controls on the speaker that came with the sub?
7/30/2013 6:32:44 PM • Dell HK395... • Answered on Jul 30, 2013
Dell HK395 Computer Speakers Logo
90 questions posted
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Audio Players & Recorders
Most Popular Question
static hk395 satalite speakers
  • Audio Players & Recorders
