20 Most Recent
Dell A525 Computer Speakers Questions & Answers
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage In the Management window select > Device Manager Next to Sound, Video and Game Controllers click the + sign A yellow triangle will signify a problem so if one is present, right-click that device and select Properties You can then choose to update the driver For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
5/11/2017 10:00:32 AM •
Dell A525...
Answered
on May 11, 2017
One speaker is MUCH louder than the other
It sound like you have a break in the main wire from the computer sound card to your speaker amp OR the plug is not plug in completely plugged in all the way. Try some other speakers or ear buds / head phones to isolate sound card problem or speaker problem.
4/25/2013 8:28:45 AM •
Dell A525...
Answered
on Apr 25, 2013
No sound and have latest
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
4/5/2011 8:45:52 PM •
Dell A525...
Answered
on Apr 05, 2011
My dell a525 speakers wont
Hello
You just need to upgrade windows by click update drives from internet "search automatically" option in device manager.
feel free to ask more if need any assistance
3/2/2011 12:16:15 PM •
Dell A525...
Answered
on Mar 02, 2011
