SOURCE: HP Photosmart c7180 unable to scan since Windows 7 computer
I'm having the same issue. I've uninstalled and re-installed the drivers several times now. I was unable to find hpqscnvw or hpqscnappi in my bin folder. I did find hpqdstcp and double clicked on it...it does nothing. I do not have hpqgrpky in my bin folder either...I DO have hpqkygrp though...I double click it and it displays the message "The scanning software was launched with improper command-line arguments. Extended error information: 8, [(-1, 0 0)]".
Any thoughts?
Thanks!
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
SOURCE: hp color laserjet cm 1312 window 7 driver
It sounds like you downloaded the PCL Universal Driver. Try the full solution driver or the PostScript Universal Driver. Both allow color prints.
SOURCE: HP psc 750 windows 7 driver issue
Please install new driver and get it downloaded here :
www.siliconguide.com > Drivers > Printer > HP
www.opendrivers.com/.../hp-free-driver-download.html
www.brothersoft.com/downloads/hp-printer-driver.html
Jay npvwql
