Radio Shack 3808 Digital Answering Machine Logo
Posted on Mar 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost manuel....how do I set the day and time....
Anonymous
Level 2:
Sergeant:
  • Expert 244 Answers
  • Posted on Mar 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
244
Questions
0
Helped
35850
Points
779
1. Turn on the system. Hold down
SKIP/TIME SET/CHECK. The
system sounds a tone after 1
second.
2. While holding down SKIP/TIME
SET/CHECK, press REPEAT/ANNC/
DAY. The system announces
"Monday" and &'?appears on the
display. Repeatedly press REPEAT/
ANNC/DAY until you hear or see the
correct day.
3. While holding down SKIP/TIME
SET/CHECK, press MEMO/2 WAY/
HOUR. The system announces "1
AM". &' appears on the display.
Repeatedly press MEMO/2 WAY/
HOUR until you hear or see the
correct hour.
4. While holding down SKIP/TIME
SET/CHECK, press PLAY/PAUSE/
MIN. The system announces "01".
Repeatedly press or hold down
PLAY/PAUSE/MIN until you hear or
see the correct minute.
5. Release SKIP/TIME SET/CHECK.
The system announces the day
and time you set.
6. To hear the current day and time,
press SKIP/TIME SET/CHECK while
the system is on or off.
Thanks!
How to set alarm
Install batteries. Press and HOLD down alarm button. While holding down alarm button, press hour button until hour is set, then press minute button until your time is set. release alarm button and set time will be saved. Activate alarm function, by selecting band and station, pressing alarm button, and alarm indicator appears and alarm is on. The station will play when alarm time is reached.
Free copy of owner manuel online
what owners manual ? wnhat company what equipment?
Lost the manuel need to re set answering
you can contact the service provider.........
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
3helpful
Hyundai gear box
sounds like you are low on gear oil
1helpful
1helpful
Changing time!
Press DSPL for two seconds
USE volume buttons to set hour
pres SEL
use volume buttons to set minute
press DSPL
TV turns on at odd hours by itself
GO to Magnavox Owners Manual---on the www.
Top Radio Shack Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
