There is an intermediate rubber roller that keeps the unit from "eating" tapes. When this roller gets dirty or shiny then it slips and the unit will eat tapes. It needs to be cleaned with a q-tip and some alcohol. It runs between the flywheel shaft and the take-up spindle. You should be able to clean it if you take off the bottom cover.
SOURCE: Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
SOURCE: Lanier tape dictation machine
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
are the Best
SOURCE: While dictating on the Lanier
Hello the alarm that you are listen is the end of the tape alarm the reason it detect a fast motion and is warning you that the tape is almost to the end but if you don't agreed that the tape is almost to the end your unit needs service you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
