20 Most Recent
Symphonic WF803 DVD Player/VCR Questions & Answers
Dvd plays but video shakes
There are so many video resolution and frame-rate modes these days that the sad reality is that some TVs are simply incompatible with some DVD/VCR equipment. Very irritating. Having said that, I would try fiddling with the settings to find a fix - but you have possibly tried all that, considering that you posted it here on FIXYA.
No sound when playing dvd
I find modern scart plugs to be pretty hopeless sometimes - I've solved the "no sound" issue by SLIGHTLY bending the pins - worth a try.
Lost remote & manual
You may view/download the manual
here. I don't see a replacement for the original remote, but you should be able to program a universal remote to work with the unit.
Need a new remote control
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.Setup codes for almost all sets are given here. Find the setup code for your device, and buy one remote control which has setup codes for your device. Brand name isn't a matter for remote control. setup codes for Symphonic must be there.
NEED CODE NUMBERS FOR UNIVERSAL REMOTE
Check these codes.0456
[0458 0227] [0899 0236]
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
Disk error with all new DVDs ???
Have you tried to clean the lazer? Or did you buy the player or DVD's in seperate parts of the country or even another country? If so, there may be a discrepancy between area codes. Don't ask me how to correct that one.
Error message
disc error msg playback may not be available on this disc.....help
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found
HereHope this helps
