20 Most Recent
Lanier 260T Desktop Cassette Voice Recorder Questions & Answers
I have a Lanier P-127,
There is an intermediate rubber roller that keeps the unit from "eating" tapes. When this roller gets dirty or shiny then it slips and the unit will eat tapes. It needs to be cleaned with a q-tip and some alcohol. It runs between the flywheel shaft and the take-up spindle. You should be able to clean it if you take off the bottom cover.
How to erase dictation
Hello Press and hold telephone and rewind at the same time for about 3 seconds the unit will start to rewind and ERRASE will be flashing on the display
While dictating on the Lanier
Hello the alarm that you are listen is the end of the tape alarm the reason it detect a fast motion and is warning you that the tape is almost to the end but if you don't agreed that the tape is almost to the end your unit needs service you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
How do you erase dictation
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Lanier p-155 won't turn on
Some times the battery contact need to be pulled out a little bit. they are located down inside the battery compartment. You can stick a small screwdriver under the battery contact and bend it upward for better contact. If that doesn't work try removing the back cover and tightening the grounding screw, which is a silver screw located by the motor pulley hole. Sometimes this screw loosens up and then the ground is lost to the entire unit
I have a Lanier Transcriber
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
