SOURCE: DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
SOURCE: 97 chevy ventura sliding doors wont open automatically
the plungers are not making good contact swivel them around
SOURCE: the disc is stuck and the display reads "No disc".
Ok one easy fix to this is to tilt the player while the system is on whilst constantly pressing the eject button. I once had to even turn the whole thing upside down then back and shake a little until the disk positioned itself properly to eject. good luck
kc
Hi
This Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
