20 Most Recent Hyundai ImageQuest HP4240 42 in. Plasma Television Questions & Answers
My 40" Hyundai TV keeps going off it comes back on wen I hit it four ten minini
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
6/6/2016 1:03:59 AM • Hyundai... • Answered on Jun 06, 2016
My Hyundai 42 plasma keeps going off then on agan when I hit it I get it back on four a few seconds
Check for any dry soldering joins in the power supply board. Also check the interconnection cables By removing and reconnecting it. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
6/5/2016 6:13:50 PM • Hyundai... • Answered on Jun 05, 2016
2answers
Plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
8/31/2015 8:13:54 PM • Hyundai... • Answered on Aug 31, 2015
2answers
Hyundai Hpt 4240 Plasma Screen tuning instructions
Try the Hyundai web site, or call their service rep.
Jerry G.
3/7/2015 6:19:57 PM • Hyundai... • Answered on Mar 07, 2015
0answers
No sound or pic
Be the first to answer 1/8/2014 7:27:45 PM • Hyundai... • Posted on Jan 08, 2014Be the first to answer
Green light stays on nd no sound or picture
use a very dark room where you cant see nothing. turn it on and tell me if there is any light on the screen "backlight" http://www.tvrepair.localdomain.me
1/8/2014 8:25:13 AM • Hyundai... • Answered on Jan 08, 2014
Power dead
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure it working , if otherwise power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to fix the fault and do take care in handling the set......
5/27/2011 7:56:49 PM • Hyundai... • Answered on May 27, 2011
The remote control for my
Try website like Remotes.com to buy an original remote.
3/16/2011 2:50:33 AM • Hyundai... • Answered on Mar 16, 2011
My son played with the remote and accidentally
You have to go into the menu and go to sound set up and turn the internal speakers on. If that don't fix the audio problem, it is possible the audio processor is locked up. To fix that problem you need to unplug the TV from the wall for 40 MIN, and that will reset the processor back to normal.
12/6/2010 5:17:37 AM • Hyundai... • Answered on Dec 06, 2010
2answers
Black lines on plasma
The matrix controler or the matrix drive area is failing. The fix is to change the proper circuit boards, and then do the factory setup to match the board is necessary. In the worse case, it may be the display screen itself that has a failure occuring.
You will have to bring the set for factory service to have the work done. If the set is out of warranty, it may be expensive to service.
Jerry G.
10/23/2010 4:38:56 PM • Hyundai... • Answered on Oct 23, 2010
I have a hyundai 42
It can be the flexy cabels. The cabels need cleaning.
8/11/2010 7:01:56 PM • Hyundai... • Answered on Aug 11, 2010
How do i get sky hd to work on this tv? i have
maybe the Hyundai service center can give you the best solution to your problem.just ask them.
6/19/2010 5:04:43 PM • Hyundai... • Answered on Jun 19, 2010
0answers
Keeps turning off after 5 minutes
Hi...
The main power supply is going into thermal shutdown
Seek a tech in person
4/23/2010 2:55:16 PM • Hyundai... • Answered on Apr 23, 2010
I lost my remote
Try website 1-800-Remotes Factory original.To buy an exact remote.
2/16/2010 11:42:30 PM • Hyundai... • Answered on Feb 16, 2010
Flickers all the time. I think its the backlight
The flickering is most likely due to a faulty inverter board and could just be a dry joint, try reflowing the solder on the connections where the wires from the bulb meet the board. obviously do not open the tv at all if you dont have the relevent electrical experience and only do it without the tv connected to the mains
11/24/2009 8:50:27 AM • Hyundai... • Answered on Nov 24, 2009
Solid yellow line down the side of the screen
Use the screen size button to change to 16:9. If it is in the mode where the TV decides, a yellow or green bar may show up for some unknown reason. (acutally, there is a reason, but not worth getting into). This works on Samsung TVs. The mode is called "Just Scan" when the TV decides what screen size to use on a Samsung. I don't know what it is called on a Hyundai.
11/18/2009 12:20:49 AM • Hyundai... • Answered on Nov 18, 2009
Just black screen
Hi i have the same problem i think it is the power board you can buy these on ebay for about £200 i havent botherd as yet as i might just buy another tv as ive had no end of trouble with it dont think i would ever buy a hyundai tv again!!
4/10/2009 6:58:18 PM • Hyundai... • Answered on Apr 10, 2009
2answers
Hyundai plasma
go here and watch part one and two
http://www.youtube.com/watch?v=9NPobj0_GSo
2/6/2009 7:09:02 PM • Hyundai... • Answered on Feb 06, 2009
Hyundai ImageQuest HP4240 42 in. Plasma Television Logo
Popular Tags
43 questions posted
Top Hyundai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hyundai Televison & Video
Most Popular Question
hyundai hpt 4240 plasma screen tuning
  • Televison & Video
