Televison & Video Logo
Posted on Jan 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung DLP TV HLM437W turns on just fine. Good picture and sound. After about 30 seconds, the TV suddenly turns off sound and picture, and 3 blinking lights show on the front screen. Allegedly, this is an indication the bulb has gone out, but the picture is just fine before the bulb goes out.
matt
Level 3:
  • Samsung Master 1,666 Answers
  • Posted on Jan 18, 2018
matt
Samsung Master
Level 3:
Answers
1666
Questions
Helped
696405
Points
9998
Sounds like swollen capacitors to me see what i mean here
Samsung LCD TV Failed Power On Clicking Repair
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Mar 26, 2008
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Anonymous
  • 51 Answers
  • Posted on Dec 27, 2008
SOURCE: 3 blinking lights - Samsung DLP
Remove your new bulb and examine the connector carefully. The inexpensive replacement bulbs tend to arc and ruin your $700 ballast; sad to say. If everything looks good, make sure the interlock switch on the bulb cover opening is engaging. It won't fire up if it thinks that door is open.
Anonymous
  • 205 Answers
  • Posted on Jun 28, 2009
SOURCE: samsung hln5065w dlp blows bulbs
The N series, needs to be told via service menu options, what type of bulb is being installed.
Anonymous
  • 17 Answers
  • Posted on Jul 11, 2009
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
NJ Logan
Pat Adams
  • 31 Answers
  • Posted on Aug 27, 2009
SOURCE: my hl 85086w Samsung DLP Rear Projection TV blinking lights
light engine or balst
1helpful
I have a Samsung DLP HLP5663WX/XAA. I repleced the lamp, I turned on the tv, has sound, no picture, and turns off by itself in 20-30 seconds.
you may have a ballast fault which provides high voltage to your bulb or lamp door switch may be at fault check for continuity.
My crt tv picture is fine. but the sound startes after about 30 seconds
Check and replace all the electrolytic capacitors at the audio output section circuit.
My samsung dlp 6163 display suddenly changed to B&W
Bad Color Wheel!!!!! Call Encompass for Part 1-800-638-3328 if out of stock call Mats 1-800-628-1118 Just looked it up encompass is out of them right now part # BP96-00674A Listed for 129.69 Go to E-Bay Lots of good deals for TV parts. E-Bay has 4 prices range from 122.00- $149.00
2answers
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Samsung DLP HLM437W won't turn on
my advice is that if the project is getting expensive kindly invest in a new tv. i am nt familiar with that set but you are having a micro processor problem replace it and your tv will work fine as it was before good luck.
1helpful
2answers
PROBLEM WITH SAMSUNG DLP TV
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
disconnect the power and hold in the power button for 30 seconds to reset it.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
