20 Most Recent Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Questions & Answers
When I turn the tv on, after a few minutes color
Could be a bad/failing fan. Is the fan still vibrating? Is it making more noise then normal? Most of the time i find that a fan going bad and vibrating raises heck with the rest of the optics in the TV.
1/2/2018 11:27:14 AM • Samsung HLP6163W... • Answered on Jan 02, 2018
0answers
Tv won't start
It is either a power supply problem or the supply trying to protect itself from a failure elsewhere.
This limiting action also can prevent an unwanted fire from overheating.
You will require service to restore your set.
3/20/2015 8:02:45 PM • Samsung HLP6163W... • Answered on Mar 20, 2015
How to replace color wheel
I have a benq projector which has a very noisy color wheel can I stop it or how do I replace it
1/25/2014 12:30:39 PM • Samsung HLP6163W... • Answered on Jan 25, 2014
My tv keeps turning off
bad solder connects on power supply pcb.........t.
6/22/2013 6:04:18 PM • Samsung HLP6163W... • Answered on Jun 22, 2013
3answers
We have a tv turning on then off and states it is overheating
You don't mention if you get a picture or not but you might want to check the lamp for signs of damage. I think you will want to check samsung's website samsung.com/support and type in your model, some of these model are experiencing similar problems and there might be a firmware update for this.
12/4/2012 10:54:59 AM • Samsung HLP6163W... • Answered on Dec 04, 2012
Samsung HLS4266w pop sound
Remove and inspect the lamp to see if it shattered inside?
10/25/2012 12:30:20 AM • Samsung HLP6163W... • Answered on Oct 25, 2012
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
10/18/2012 2:35:40 AM • Samsung HLP6163W... • Answered on Oct 18, 2012
Where are the lamps located on the samsung HLP6163wx
Hi,The lamp is on the back of the TV. Remove the little door or the back cover to get to the lamp.Here is the link for the video showing you how to remove the lamp.http://www.youtube.com/watch?v=0jr_9A5Xd2QGood luckwww.aaatvservice.com
9/3/2012 2:54:44 AM • Samsung HLP6163W... • Answered on Sep 03, 2012
Samsung HLP6163WX picture shuts off.
Likely the DMD unit which is part of the light engine--if have to unplug set the microprocessor is getting scrambled and cannot operate. Common and fatal issue as to replace the light engine the cost will exceed the value of this set---DMD can be purchased alone but costs almost as much as the whole engine that comes with it.Seen several of these sets---a shame but even at wholesale the part to fix it makes it not worth fixing.
6/1/2012 4:00:31 PM • Samsung HLP6163W... • Answered on Jun 01, 2012
Burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
4/6/2012 2:29:00 AM • Samsung HLP6163W... • Answered on Apr 06, 2012
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
129 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
lamps located samsung hlp6163wx
  • Televison & Video
