This might be an issue with your web cam settings or the web cam itself. Try going through the options of the web cam to see if there are any settings making the web cam display everything pink. If not then try the web cam in another computer (I'm assuming you have a desktop with an external web cam) see if the video is still pink. If it is then there is an issue with your web cam if not then it is an issue with the settings on your computer
In the event that you are using a laptop with a built in web cam you might want to check if you still have a warranty to get the web cam repaired.
Hope this helps
It sounds like the problem is related to your web cam. What is the model of your web cam?
