Question about Necchi 3102 Mechanical Sewing Machine
How do you raise the feed dog
This is a Necchi 3204FB. bought it used and has no manual.
Also, can you help me find a manual.
Right now, I cannot get the feed dog up - it is lowered.
Thanks for any help you can give me
GW
I realize this is a year too late, but maybe someone else can benefit from this answer... I have a 3204B and the feed dog is to the right of the bobbin area. It has red lettering on the face and requires a little umph to raise it.
Posted on Mar 04, 2009
    New Friend:
I need a foot peddle for a model no 3204fb
Posted on Jan 29, 2017
  • R.A. Ellis
    R.A. Ellis Jan 29, 2017
    Try posting a "new" question on FixYa. Adding onto an old post will most likely get you very few results.
SOURCE:
Necchi 4575 feed dogs won’t work does not push material through
If you raise the presser foot, set the stitch length to a 3 or higher, then slowly press the foot control, can you see the feed dogs rise, move backward, then drop and come forward again? If they are not moving, the feed dogs have seized. If they are moving but do not rise above the needle plate, then you have them disengaged.
If they are seized, resist the temptation to run the machine anymore until you can get it serviced. It could damage the motor causing more repair cost.
If they are disengaged (dropped), then you need to find the control lever or dial that engages them.
Jun 23, 2018 | Necchi Sewing Machines
Feed dog on Necchi 681c has drop,how do I fix it?
A lot of machines have a control knob/lever that raises and lowers the feed dogs. However, remember that when the control is activated, the feed dogs will not rise until the machine actually begins to stitch.
If the feed dogs do not rise, then there is most likely a problem and needs to be serviced.
Feb 14, 2017 | Necchi Sewing Machines
I have a Necchi 537FA and I want to know what the knob (on the right hand side) with the dot and knit symbol does. This knob is the last one on the right hand side. Thanks in advance for the help.
I suspect the knob on the lower right hand side is the feed dog knob. The "knit" symbol is for the feed dog. One setting drops the feed dogs so you can move the fabric yourself, ie free motion quilting. The other setting raises the feed dogs so the machine will feed the fabric for you.
to find a manual, Search the internet:
Brand + Model + the word "Manual"
Aug 19, 2015 | Necchi Sewing Machines
On Model #535 FA The feed dogs do not come up high enough to advance the fabric forward. Is there an adjustment to raise the feed dogs ? ( Necchi sewing machine )
If you change the number of your stitch length it will automatically adjust the feed dogs. If it is still a problem then you will need it adjusted. Insure that your pressure foot is placing enough pressure that causes the feed dogs to pull the material forward. To adjust the feed dogs there are different ways to be adjusted. I wouldn't suggest you try to adjust the height of the feed dogs.
Feb 19, 2015 | Necchi Sewing Machines
How to depress the feed dog. I lost my owner's manual
On some machines there a lever on the right side of the machine you can use to remove the face plate and just raise it up to cover the feed dogs. Hope this helps.
Oct 20, 2014 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
How do you raise the pressure foot on the Necchi 3204fb sewing machine?
the presser foot lever is either on the left side of the machine where face plate is or at the back of the of the machine on the left
Nov 22, 2010 | Necchi 3102 Mechanical Sewing Machine
I have a Necchi Logica 592 that I purchased new in 1987. The feed dogs do not raise to the proper position and the fabric won't feed through. I need a repair manual and the part (parts) to fix it.
If , you go to www.tias.com you wil be able to purchase a copy of a technicians book, the Sears Kenmore Sensor Sew 100 was the same machine, Necchi made it for them. Parts are going to be next to impossible to get. My motor is shot, but everything else is like brand new, boards etc. I bought the book and that is why I knew it was the motor. Sometimes, ebay will have one for sale, but they want too much. I am using mine as a doorstop, LOL, I paid $800 for it new in 19884. Good luck
Sep 04, 2010 | Necchi Sewing Machines
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Necchi 3102 Mechanical Sewing Machine Logo
420 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
