Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to reload Router back onto system, after several attempts
Anonymous
Level 2:
Scholar:
  • Expert 57 Answers
  • Posted on Mar 05, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
57
Questions
Helped
11983
Points
190
Can you clarify what you mean by getting the router "back onto system"?
It may be you just need to reset the router back to factory settings. To do this:
1. Hold down 'reset' button on router for 5-10 seconds while the router is powered on.
2. The unit will reset.
3. Get on a computer that is connected to your wireless or wired network and point your browser towards the following address:
192.168.2.1
4. If prompted for a password, enter
username: admin
password: admin
5. You should now be at the router's set up menu. It would be wise to change your router's admin password for security purposes.
Further information can be found at the router's online manual, available here:
http://support.dell.com/support/edocs/network/p57205/en/index.htm
Anonymous
Level 3:
  • Master 797 Answers
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
191189
Points
2336
The router does not need to be loaded onto the system. What is the exact problem you are having?
1helpful
The router configuration page does not load correctly.i have to reload the page several times to get the configuration page.Many times when i click on apply settings,it do not work.Please can anyone h
How to upgrade firmware on ASUS RTG32:
  1. Go here ASUSTeK Computer Inc Support Search
  2. Select your router (by clicking Download)
  3. Select your OS
  4. Click on Firmware and download the one that suits your country.
  5. Click on Ultilities and select the one that suits your country.
  • Global is the direct link.
  • Global (DLM) uses your browser's Download Manager.
Launch the Utility and follow the on-screen instructions.
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
1helpful
This unit is a bare minimum netbook on windows CE. Internet explorer preloaded onto the unit is the only browser usable.So far as i can tell you cannot check for correct drivers. I don't think you can...
Base on other internet comments this system has a terrible time hooking to the Internet and staying connected even when everything is just so. You need to keep after Sylvania support as only they can fix this puppy.
Sorry, but this might be a dud.
Jim
1helpful
I have a Lynksys wrt54g router. I had to reload my operation system completely due to a software issue. I can't get onto the internet system without being plugged into the router. I had wireless access...
Check in device manager to see if you have the drivers installed for your network adapter (look for yellow exclamation marks).
If they are all ok, have you put your password in for your wifi security
Con't connect to internet through d-link dir 625 router
  1. Reset the router and your modem.
  2. unplug the router's power
  3. unplug the modem's power
  4. wait 15 seconds
  5. plug in the modem
  6. wait until you have several lights and not too much blinking
  7. plug back in the router.
Try logging going to website. Give it a couple of tries (refreshes). Sometimes it takes the router time for the first attempt.
Report how that goes.
Reloading backed-up song data on Boss Micro BR
Are you transfering from one disk to another on your computer? There is a possibility that the format of the original disk is not being recognized.
2answers
Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Philips cdr600
Needs a new laser or realigning service using philip's COMPair diagnostic system.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
