20 Most Recent Boss Micro BR Digital Recorder Questions & Answers
I Own This Unit And I Tell You What I Love It And Cant See Myself Using A Computer Anytime Soon. You Can Open It Up And Check For Loose Connections By Removing The Screws Shown Here
Youll Wanna Remove The Disk Drive Cover First Indicated By The Blue Dots. Once Inside There Arent Many Connections To Check But Now You Can Unplug The Hard Drive And Try Powering The Unit On Again. See If You Get The Same Result. Once Thats Done Plug The Hard Drive Back In And Try Again To See If It Works.
If It Doesn't Call Roland Theyre Costumer Support Is Awesome And They Can At least Give You An Idea Of What May Be Wrong.
Roland Corporation U.S.
5100 S. Eastern Ave.
Los Angeles, CA 90040-2938
323-890-3700
Also Very Helpful Is This Guide On How To Remove The Hard Drive And Replace It Found Here.
I Hope Some Of This Helps.
Boss Micro BR... | Answered on Apr 09, 2019
MICHAEL SCOTT: YOU PASSED ALONG SOME GREAT INFORMATION BUT IT ONLY GETS ME HALFWAY THERE...
I HAVE ALL THE NECESSARY CABLES HOOKED UP. DO YOU HAVE TO RECORD MY SONG FROM THE 1180 TO AUDACITY OR WHAT?...THIS IS ALL NEW TO ME AND IT MAY WORK BUT TELL ME HOW TO RECORD FROM THE 1180 TO AUDACITY.
THANKS...GEORGE SLADEK
Boss Micro BR... | Answered on Mar 19, 2019
Incorrect SD card.
Boss Micro BR... | Answered on Jan 24, 2018
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Boss Micro BR... | Answered on Dec 17, 2017
I can do that, but I am in Caracas, Venezuela.
Cheers, mate !
Boss Micro BR... | Answered on Dec 14, 2017
Format the media using the recorder. There are some special programs around to convert the data. These proprietary formats are a problem when not formatted on the Micro BR itself.
Boss Micro BR... | Answered on Aug 10, 2017
They should be commercial screws, probably metric. You would need to find out the pitch (with a gauge), diameter, length and head type from one of the other screws. Usually all Boss products share parts, so the parts could be scavenged from an old, useless pedal. The missing knob, too. As for the internals and electronics, take it to a tech. Amp techs sometimes accept checking pedals.
Boss Micro BR... | Answered on Jul 26, 2017
If the disk had music that was not CREATED on the BR-8 you will get the error. The format is incompatible with computer formats.
If the files were created on the same BR-8, then you probably have a disk drive failure.
Try initializing a blank disk. If it will not, then you have a drive failure.
Also is it possible you are trying to read a 250Mb disk on a 100Mb drive? That won't work either.
Boss Micro BR... | Answered on Apr 13, 2016
You can download the manual here
Hope it helps.Thanks!
Boss Micro BR... | Answered on Mar 26, 2016
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Boss Micro BR... | Answered on Feb 23, 2016
Probably the level is set too low when you are bouncing to track 7 and 8.
Boss Micro BR... | Answered on Aug 09, 2015
The devices that have battery AND adapter capability OFTEN have a switch that the adapter opens when powered by the adapter. Often this switch contact gets bent and units won
t run on battery, so try it on an adapter... if the adapter works and battery doesn't, this contact whcih is a part of the input power connector has failed.
Boss Micro BR... | Answered on Jul 05, 2015
If the disk had data put on with a PC you might try deleting all files and folders using the PC before formatting the disk in the BR8.
It is also possible that the media has gone bad.
A final try would be to degauss the disk and try to format on the BR8.
Boss Micro BR... | Answered on Dec 12, 2014
"it never works"... this is NOT enough information for us. You are not telling us how the CD is tested. If you are testing it in a boombox type player, that is not a test. First thing is to look at the bottom of the CD to see if you can detect written tracks... with right lighting you can tell if it has been burned. REMEMBER that CD's, unlike phonograph records, are written from the middle outward. Many consumer players have trouble playing CD's that are written but not "finalized". If you CAN see written area (compare to unburned CD) then likely the burning is taking place, and the problem is the format is either not complete or incompatible with your player. Try reading the disk in your computer. Also you might want to visit the forums for the Boss/Roland workstations at VSPLANET.com.
Boss Micro BR... | Answered on Sep 09, 2014
Boss Micro BR Digital Recorder Logo
193 questions posted
Top Boss Music Experts
Michial Gueffroy
lorenzo carolus
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
View Most Popular
Boss Music
  • Boss Music
Most Popular Question
card full error when card in fact
  • Music
