Landice L8 LTD Cardio Trainer Treadmill Logo
Posted on Mar 05, 2011
Landice L8 automatically turns on by itself - Landice L8 LTD Cardio Trainer Treadmill
A
Anonymous
It is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
Hi. I have an L8 Landice Executive Trainer treadmill and it started to make an excessive noise. Please let me know what we should do. Vincenzo DiMaggio
You need to open it and cheek the belt and the bearing ,cheek for wear and tear if past inspection try lubricant ,all the best.
I have had a Landice L8 for many years and it works well. Now it simply comes on by itself. I turn it off and it comes back on. I tried unplugging it but when I plug it in it just comes on again.
is this a home model and did you buy originally? the reason I ask is that Landice home L8 models have a lifetime parts warranty. contact Landice and they will be able to assist you over the phone for free. you either need a new keyboard panel(bad buttons), or a new lower computer board. both easy fixes on a Landice
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
How do i fix an landice l8 trainer l5 error
that is a loss of speed error. you only get rid of it when the belt starts moving again
Landice executive L8 treadmill makes clunking noise when I run on it
You need to get someone out to look at it. Noise issues are rarely able to be diagnosed remotely.
1helpful
Landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
Landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
[email protected]
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Top Landice Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
