20 Most Recent Landice L8 LTD Cardio Trainer Treadmill Questions & Answers
2answers
How do I calibrate elevation grade for treadmill?
Hey there, sorry to hear you're having an issue with your elevation motor. I would be happy to help you solve the problem. Since you already installed your motor you can go straight into diagnostic mode. To get into Diagnostic Mode on your L8 Make sure to turn off your treadmill. -ET's - Press Menu and Start at the same time -CT's - Press Manual (or Display^) and Start at the same time -All other L SERIES mills - Press Display (or display and Start at the same time SideNote- -*CT's that were manufactured after 09/2003 - Press Display and start at the same time. Few things you want to do, if you haven't already. A. Align the motor with the clevis mount and install the motor mounting pin. B. Insert hitch pin. C. Reconnect the elevation harness to the lower board D. Set the lowest limit switch by holding the UP elevation button for 5 seconds. Then press and hold the DN elevation button one more time to make sure you only hear a click. E. For L7/L8 machines; Thread the elevation nut to where its flush with the threads on the "worm' shaft. F. Mount the elevation nut to the leg assembly by lining up the holes on the leg assembly. You may have to move the leg assembly so that the holes on the elevation nut line up. Then slide the two elevation pins through the elevation assembly and into the elevation nut. then secure the pins with the 2 set screws. To calibrate your potentiometer you can try to adjust while it is installed but for best results you must calibrate it before its in your motor housing. G. Calibrate the elevation potentiometer and to do so you must; 1st: Visually confirm treadmill is leveled. (0% grade) 2nd: Adjust the settings as follows; All L SERIES millls should read 0.0 3rd: If the setting is incorrect, follow these steps. Step 1: Turn the post of the potentiometer all the way CLOCKWISE. Step 2: SLOWLY turn the potentiometer COUNTER CLOCKWISE until the setting is correct. H. Carefully install potentiometer into the motor housing *NOTE: The setting may vary when inserting the potentiometer into the motor. As long as the change is minimal, fine adjustment can be achieved by rotating the meter while inside the elevation motor. I. Press OFF to turn treadmill off. Then restart the machine in manual mode to TEST elevation after resetting your potentiometer. As long as the change is minimal, fine adjustment can be achieved by rotating the potentiometer while inside the elevation motor. For more Diagnostic features and possibly further detail, I will be attaching a Link to your machines service manual. I hope this helps, always hear to help. SportSmith. http://www.sportsmith.net/images/product_support/landice/Manuals/Service/P0472050%20L%20Series%20Service%20Manual.pdf
9/3/2022 11:53:53 AM • Landice L8 LTD... • Answered on Sep 03, 2022
2answers
Pulley slipping on front roller
Since the drive pulley is slipping on the roller itself, then the front roller will need to be replaced.
8/20/2022 6:55:35 PM • Landice L8 LTD... • Answered on Aug 20, 2022
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
9/19/2017 12:13:23 AM • Landice L8 LTD... • Answered on Sep 19, 2017
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment B) Speed sensor is damaged or faulty C) Display cable is damaged or faulty D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary. B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary. C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary. D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary. Details about LS Error on Landice Series Treadmills with Belt Movement
2/4/2015 10:44:52 PM • Landice L8 LTD... • Answered on Feb 04, 2015
Why does the display say L5
this a problem in 2 ways:1) test the input voltage motor, if there are the motor need repair.2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.see the block diagram atached.9_8_2012_12_28_22_am.gif
9/8/2012 12:28:29 AM • Landice L8 LTD... • Answered on Sep 08, 2012
Landice L8 automatically turns on by itself
It is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
3/5/2011 4:18:09 PM • Landice L8 LTD... • Answered on Mar 05, 2011
Landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
9/14/2010 2:39:24 AM • Landice L8 LTD... • Answered on Sep 14, 2010
The treadmill belt is making a noise and feel like
If it has a low pitch growling when you start unit then the running belt is too tight and the adjusting bolts need to be backed until the growling noise is lessened or eliminate without the running belt slipping.
If it is the drive belt slipping, the adjustment bolt is underneath the frame so you will need to elevate the treadmill and adjust the bolt until slippage is eliminated without over tightening the drive belt.
6/14/2010 6:51:51 AM • Landice L8 LTD... • Answered on Jun 14, 2010
Landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
[email protected]
4/25/2010 5:38:09 PM • Landice L8 LTD... • Answered on Apr 25, 2010
Landice 8 over speed protection
first screen shows any error number? for what you describe I think it is simply speed sensor, try to check the cables leading to the sensor card. and then checks whether the sensor is aligned correctly.
Check speed sensor alignment.
It should be within 1/16" of the flywheel
and parallel to the flywheel.
Is it out of position?
2/6/2010 2:42:20 AM • Landice L8 LTD... • Answered on Feb 06, 2010
Blower on my citreon zsara hd estate only works on full blow
hi i get this prob a lot on peugoet 406
its the ignition worn, try wiggle the key when running and it should work if not get back to me.
9/19/2009 6:21:47 PM • Landice L8 LTD... • Answered on Sep 19, 2009
I have a Landice L7 treadmill and it will turn on and start moving all by itself without pressing start.
Hello, it is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
4/24/2023 2:46:30 PM • Landice Exercise... • Answered on Apr 24, 2023
My Landice L7 treadmill for home use races to speed when I turn it on. I cannot control the speed, it just increases automatically to top speed.
There could be a few different things causing your Landice L7 treadmill to race to top speed when turned on. Here are some potential causes and solutions:
  1. Motor Control Board: The motor control board may be malfunctioning and sending the treadmill into top speed automatically. If this is the case, you will need to replace the motor control board.
  2. Console Board: The console board may be sending incorrect signals to the motor control board, causing the treadmill to race to top speed. If this is the case, you will need to replace the console board.
  3. Speed Sensor: The speed sensor may be malfunctioning and sending incorrect signals to the motor control board. If this is the case, you will need to replace the speed sensor.
  4. Calibration: The treadmill may be out of calibration, causing it to race to top speed. To recalibrate the treadmill, consult your owner's manual for instructions.
It's recommended to consult with a qualified technician to diagnose and fix the issue to avoid causing further damage or injury.
2/26/2023 11:57:05 AM • Landice Exercise... • Answered on Feb 26, 2023
Landice L7 Problems. It runs fine until drops below 2 miles per hour and then it stops for 2 or 3 seconds and starts back up for 2 or 3 seconds.
It sounds like you normal routine has made the motor hot and then when you slow down the residual heat is causing the motor to cut out. Check the vents in the motor for fluff or blockage. https://www.google.com/search?q=Landice+L7+treadmill+stopping+at+cool+down ..
11/29/2022 1:48:38 AM • Landice Exercise... • Answered on Nov 29, 2022
Landice L9 Treadmill display not working.
Troubleshooting and link to Landice Support in the link. https://www.google.com/search?q=Landice+L9+Treadmill+display+not+working ..
11/3/2022 5:04:01 PM • Landice Exercise... • Answered on Nov 03, 2022
Hi. I have an L8 Landice Executive Trainer treadmill and it started to make an excessive noise. Please let me know what we should do. Vincenzo DiMaggio
You need to open it and cheek the belt and the bearing ,cheek for wear and tear if past inspection try lubricant ,all the best.
11/30/2018 3:46:18 AM • Landice Exercise... • Answered on Nov 30, 2018
Landice L8 LTD Cardio Trainer Treadmill Logo
29 questions posted
Top Landice Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Landice Exercise & Fitness
Most Popular Question
display say l5
  • Exercise & Fitness
