20 Most Recent Landice L9 Cario Trainer Commercial Treadmill Questions & Answers
Install elevation motor l9 treadmill
could be bad lower board I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
10/15/2017 12:48:42 AM • Landice L9 Cario... • Answered on Oct 15, 2017
4answers
The windscreen wipers on my ford galaxy won't
there is a bush on the rotor arm and it can sieze up .you need to strip it down and release the wiper arm ,then put plenty of WD40 on.its fiddly getting at the motor and other parts,but try this befor getting a new motor £350 +. worked for me.once freed switch them on periodically.
1/10/2014 6:44:59 AM • Landice L9 Cario... • Answered on Jan 10, 2014
The belt hangs or slips. Makes noise.
Lubrication may not be the issue, belt tension could cause the slipping at the end of the unit their is 2 tension bolts. 1/4 turn clock wise on these bolts will increase belt tension, start with 2 quarter turns on each bolt then start unit and proceed to walk on it, see if slipping has stopped. If not repeat procedure only turning the bolt 1 1/4 turn at a time until until proper tension is achieved. If the unit need lubrication then us a tube of clear silicone which you can purchase from Landice,
Call them @ 1-800-526-3423
7/19/2010 4:15:54 PM • Landice L9 Cario... • Answered on Jul 19, 2010
Landice L9 Treadmill - Loss of Speed Signal Code
at starting, trys to go to speed and then reads LS on screen and runs very slow, with no response to any buttons.
5/18/2010 11:56:19 PM • Landice L9 Cario... • Answered on May 18, 2010
I have a Landice L7 treadmill and it will turn on and start moving all by itself without pressing start.
Hello, it is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
4/24/2023 2:46:30 PM • Landice Exercise... • Answered on Apr 24, 2023
My Landice L7 treadmill for home use races to speed when I turn it on. I cannot control the speed, it just increases automatically to top speed.
There could be a few different things causing your Landice L7 treadmill to race to top speed when turned on. Here are some potential causes and solutions:
  1. Motor Control Board: The motor control board may be malfunctioning and sending the treadmill into top speed automatically. If this is the case, you will need to replace the motor control board.
  2. Console Board: The console board may be sending incorrect signals to the motor control board, causing the treadmill to race to top speed. If this is the case, you will need to replace the console board.
  3. Speed Sensor: The speed sensor may be malfunctioning and sending incorrect signals to the motor control board. If this is the case, you will need to replace the speed sensor.
  4. Calibration: The treadmill may be out of calibration, causing it to race to top speed. To recalibrate the treadmill, consult your owner's manual for instructions.
It's recommended to consult with a qualified technician to diagnose and fix the issue to avoid causing further damage or injury.
2/26/2023 11:57:05 AM • Landice Exercise... • Answered on Feb 26, 2023
Landice L7 Problems. It runs fine until drops below 2 miles per hour and then it stops for 2 or 3 seconds and starts back up for 2 or 3 seconds.
It sounds like you normal routine has made the motor hot and then when you slow down the residual heat is causing the motor to cut out. Check the vents in the motor for fluff or blockage. https://www.google.com/search?q=Landice+L7+treadmill+stopping+at+cool+down ..
11/29/2022 1:48:38 AM • Landice Exercise... • Answered on Nov 29, 2022
Landice L9 Treadmill display not working.
Troubleshooting and link to Landice Support in the link. https://www.google.com/search?q=Landice+L9+Treadmill+display+not+working ..
11/3/2022 5:04:01 PM • Landice Exercise... • Answered on Nov 03, 2022
Hi. I have an L8 Landice Executive Trainer treadmill and it started to make an excessive noise. Please let me know what we should do. Vincenzo DiMaggio
You need to open it and cheek the belt and the bearing ,cheek for wear and tear if past inspection try lubricant ,all the best.
11/30/2018 3:46:18 AM • Landice Exercise... • Answered on Nov 30, 2018
What is the problem with the landice l7 when you the code CE
Communication Error between upper and lower board generally produced by a physical disconnection between harness and the the apparatus. Reseat the harness.
1/4/2018 12:58:27 AM • Landice Exercise... • Answered on Jan 04, 2018
How do I replace the speed sensor on the Landice L9 pro sports cardio trainer?
the speed sensor is in the front drive wheel. it is a sensor located on the left-hand side you will see a wire going to the sensor. then a magnet is on the wheel and when it passes by you get your speed. I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
10/15/2017 12:45:45 AM • Landice Exercise... • Answered on Oct 15, 2017
I have had a Landice L8 for many years and it works well. Now it simply comes on by itself. I turn it off and it comes back on. I tried unplugging it but when I plug it in it just comes on again.
is this a home model and did you buy originally? the reason I ask is that Landice home L8 models have a lifetime parts warranty. contact Landice and they will be able to assist you over the phone for free. you either need a new keyboard panel(bad buttons), or a new lower computer board. both easy fixes on a Landice I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
10/15/2017 12:43:44 AM • Landice Exercise... • Answered on Oct 15, 2017
I have a landice l7 treadmill that is vibrating even when the drive belt is removed, any ideas?
Check the motor for its stability . If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
12/16/2016 3:31:02 PM • Landice Exercise... • Answered on Dec 16, 2016
tip
OS or O5 Error on Landice L-Series Treadmills
Probable Cause
An OS or O5 error on the Landice L-Series treadmills, such as the L7, L8 and L9, indicates an over speed condition and this occurs when the actual speed of the running belt is faster than the set speed. The possible causes for an overspeed, OS or O5, error are: A) User weight is over 200lbs, treadmill elevation is set between 10% and 15% grade and speed is set between .5 mph and 3 mph B) User is pushing against treadmill belt causing it to go faster than the set speed C) Defective lower board or misaligned speed sensor D) Maladjusted speed potentiometer
Corrective Action
A) Gravitational force will enable the user's weight to move the treadbelt faster than the set speed. The speed sensor will pick up this increase in flywheel speed and sends this information up to the display electronics. The microprocessor will then compare the actual speed to the displayed speed, determine a runaway speed condition and shut the treadmill down. An overspeed will display in the window. This is a safety feature built into all treadmills that utilize closed loop speed circuitry. The way to address an over speed condition due to gravity is have the user decrease elevation below 10% or increase the speed. B) Similar to the gravitational force, a user can be holding onto the handrails and pushing the running belt in such a manner where they are using the treadmill like a manual machine rather than a motorized one. User needs to set speed compatible for their actual walking or jogging speed so they are not pushing the belt. C) It's possible a blown motor control board is the problem. This occurs more frequently with PWM drives than SCR drives. However, this problem is becoming rare due to the PWM circuitry which senses this condition and shuts itself down before the drive motor receives any DC voltage at all. This means you'll get an LS or L5 error if your PWM is blown, not an OS or O5 error. This is a safety feature on all Landice home treadmills with PWM motor control boards. The SCR motor control boards also have internal protection to prevent an over speed condition from occuring due to an internal component failure. In the rarest of cases, on home treadmills, a faulty relay board can cause an OS or O5. To verify this, using a digital voltmeter, with treadmill turned on, measure the DC voltage between the V+ and P1 on the PWM board. The reading should be between 6-7 VDC. Also measure the DC voltage between P1 and P2 on the PWM board. The reading should be between 0.5 VDC and 6-7 VDC. If either of these voltages measure zero, replace the relay board. D) Get into Open Loop Speed mode and check the speed. Adjust pots as necessary to bring up correct speed for max and min.
http://www.sportsmith.net/support.aspx?did=BAB0DA9A-857E-41B3-A1DD-3DC0663BB9A4
Treadmill speed is not correct for landice l7
Unit may be in kilometers. Switch to miles.
1/4/2014 8:17:20 PM • Landice Exercise... • Answered on Jan 04, 2014
Speed sensor L5
follow this steps and fix it. God bless you SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH belt movement This is usually an indication of a speed control malfunction. The upper board is not recognizing a signal pickup from the speed sensor. This could be due to the speed sensor being misaligned, improper connection, or bad speed sensor. Refer to the flowchart on page "SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement The speed sensor is not recognizing any motor movement. This displays the error message to the upper board. NOTE: USE THIS FOR DIAGNOSING THE PWM/RELAY COMBO BOARD
10/21/2013 12:37:57 PM • Landice Exercise... • Answered on Oct 21, 2013
What causes a landice treadmill to start then stop then start and stop then shut down on overspeed
How long does it run for when it starts...you need to give a detailed description for better diagnosis
8/13/2013 3:01:24 AM • Landice Exercise... • Answered on Aug 13, 2013
Landice L9 Cario Trainer Commercial Treadmill Logo
11 questions posted
Top Landice Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Landice Exercise & Fitness
Most Popular Question
install elevation motor l9 treadmill
  • Exercise & Fitness
