1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Check the hole where you put the capsule, are there any faults or obstructions visible? If not be very suspicious of your capsules, there are lots of brands of Nespresso coffeemakers and the capsules have slight variations between the different brands. The variations are almost invisible but enough to prevent the wrong capsules being used.
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
