Logitech H760 Wireless Headset Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I connect the USB for headset into system it messes up my internet wireless connection. when I take USB out my internet will work fine again
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
456
Points
My one was not syncing as well - it was defect. I asked for an exchange and the new one works like a charm!
Anonymous
Level 2:
Scholar:
  • Expert 105 Answers
  • Posted on Mar 02, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
105
Questions
0
Helped
42852
Points
332
The wireless transmitter for your headset is causing interference with your wireless network.
If you can move your wireless networking equipment away from the USB transmitter then this may lessen the problem.
Perhaps using a usb cable extender will allow you to move your USB transmitter away from your computer?
Hope this helps,
Chris
1 Related Answer
mardoo6
Matthew Kubin
  • 162 Answers
SOURCE: When I connect my USB
I think the problem is, that your wireless router is too close to the wireless connector of the headset, it's just a guess, but try to move them at least 3 meters apart.
The other thing that could cause trouble is the driver from logitech. Maybe your firewall is disabling all internet connection when the driver is trying to connect to the internet. Try to disable the firewall/antivir.
Or it's just the same frequency, but that's probably not possible.
I hope I could help you =)
Can a wireless headset be used with NEC SL1100 Phone
The NEC SL1100 phone can be used with a wireless headset, but it will require a specific type of connection.
The NEC SL1100 phone has a 2.5mm headset jack, which is not compatible with most wireless headsets, which typically use a USB or Bluetooth connection.
To use a wireless headset with the NEC SL1100 phone, you will need a USB-to-2.5mm headset adapter or a Bluetooth-to-2.5mm headset adapter.
The Plantronics CS50 wireless headset is not directly compatible with the NEC SL1100 phone. However, Plantronics offers a USB-to-2.5mm headset adapter which can be used with the CS50.
It's worth noting that some NEC SL1100 phones are equipped with a built-in Bluetooth module, which allows you to connect a Bluetooth headset directly. To check if your NEC SL1100 phone has this feature, you can check the user manual or contact the manufacturer.
It's important to check the compatibility of the wireless headset and the phone system, before making any purchase. It's recommended to consult the manual of the phone system or the technical support of the phone system provider to ensure that the wireless headset you plan to purchase is compatible with the phone system.
My sony pulse headset works fine except every once in awhile it cuts out (will be talking in group then sound cuts off cant hear or be heard) for about 30 sec then works again. batterys not low, blue light...
I was having this issue while using this headset on my PS4. I bought a small,2ft USB extension, to move it away from the PS4 console by about 2 feet and now it works perfect. It was something about the interference from the remote controls. Hope this helps.
1helpful
The audio kept cutting in and out while using the Samson Stage 5T 3-in-1 Headset Wireless. It lost audio for about 30 seconds at a time. At the time, it was connected to a Samson MR 1064 Mixer that was...
The unit is SUBJECT to radio interference from other systems in the area such as high power taxicab radios for example and other services. 30 seconds might be about the time for a radio transmission. The system, while being interfered with, likely will NOT generate audible sounds and due to the squelch algorithm may MUTE the system.
Sorry, but you are a SECONDARY user per FCC definition and they are licensed and you are sharing bandwidth. You cannot interfere with them, but they can interfere with you. You should probablly get a UHF system that has less chance of interference. While recording, frankly I would be wired, not wireless. I am both an electrical engineer nd a HAM so I am aware of these problems.
When I connect my USB into system it messes with my wireless internet connection. As soon as I unhook it my internet connection is fine again.. Any Suggestions?
1helpful
2answers
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Truemobile 1300 w/l usb adapter problem
hi..
if i understand your issue your computer connected to the internet using the wireless adapter but get disconnected after rebooting...right?
did u try updating the software for the wireless card..
here is the link trying updating the drivers for the wireless usb adapter..
here is the link for the download--
http://www.softwaredriverdownload.com/download.php?file=2nxZnRwOi8vZnRwLnVzLmRlbGwuY29tL25ldHdvcmsvUjE0MzM1NS5FWEU%3D..
good luck........
vedhick
5helpful
XBOX 360 Wireless Controller PC Connection Problem
WARNING: try at your own risk!
I kind of fixed it. The problem appears to be with the USB controller - specifically, my mouse (a Razer Copperhead) and the XBOX 360 wireless receiver. A lot of work went into the solution, but I essentially ended up uninstalling and unplugging all of my USB devices (you can uninstall them using device manager in System Properties>>Hardware within Control Panel. Look for Universal Serial Bus and uninstall everything in that category). Reboot. Then, I first plugged in the device in question (my 360 receiver). Afterwards, I one by one plugged in each item until I found the one conflicting with the receiver (my mouse). After that, I uninstalled all devices again and next uninstalled the drivers for the conflicting device (my mouse in this case) and rebooted again. After this, I tried several times to uninstall and reinstall the mouse and various USB devices until finally it worked (sort of).
I call this a partial solution because now I appear to have the opposite problem. My mouse seems to be conflicting with another device (probably the 360 receiver). My mouse refresh rate is very choppy. The good news (for me) is that I can uninstall the USB controller for the mouse, reboot, and both the 360 controller and the mouse will work fine... that is until shut down. Then I have to uninstall the mouse controller and reboot again. Needless to say, I keep my computer on more than usual now.
Wont connect to wireless network
first, I suggest trying a different USB port. remove the adapter and the icon should disappear, so if the usb port is loose or broken that may be why its acting like that. Plug it into a different port and try it. You may have to reinstall the driver for the next usb port depending on your system
Top Logitech Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
