20 Most Recent
Logitech H760 Wireless Headset Questions & Answers
When I connect the USB
The wireless transmitter for your headset is causing interference with your wireless network.
If you can move your wireless networking equipment away from the USB transmitter then this may lessen the problem.
Perhaps using a usb cable extender will allow you to move your USB transmitter away from your computer?
Hope this helps,
Chris
When I connect my USB
I think the problem is, that your wireless router is too close to the wireless connector of the headset, it's just a guess, but try to move them at least 3 meters apart.
The other thing that could cause trouble is the driver from logitech. Maybe your firewall is disabling all internet connection when the driver is trying to connect to the internet. Try to disable the firewall/antivir.
Or it's just the same frequency, but that's probably not possible.
I hope I could help you =)
I have just bought
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected.
Hope this helps.
