Microsoft Xbox 360 Console Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
XBOX NOW PLAYS IN BLACK AND WHITE WITH OLDER TV DID WORK FINE AND DOES ON NEW HDTV ALL CABLES GOOD NOT SURE WHAT TO DO TO GET COLOR BACK
Anonymous
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Mar 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
22745
Points
245
It may be possible that you are simply connecting the gaming system to the TV incorrectly (if the issue is confined to one specific TV) so check to make sure that you are using the right connectors in the right place for that TV.
If you're saying that the color is black and white on two separate TVs, this would likely be an issue with your gaming system.
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
6565
Points
60
There is a switch that changes the video cable from SD( for use with older TV's without high definition connectivity) to HD (used for newer HD TV's with high definition.
If your older television is using a composite (yellow) connection for video, make sure the switch is in the SD position and NOT hd.
1helpful
I have the new black xbox. We just changed tvs to a new plasma samsung and when i plug all of the cords in and turn on the xbox it works, except that the colors are bloack and white. It gives a good...
make sure that if you have the hd cords plugged in the switch is on hdtv and if the regular cords are plugged in the switch on the a/v cords says tv. make sure the red cord is in the correct socket. if you are using hdmi cord then it needs replacing. also you may find some sucess by changing the output in the xbox settings.
Have a Konka TV but ps2 doesnt play through it.
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
1helpful
Xbox 360 plays in black and white
Well, I have a couple of solutions that might work...
  1. Check your AV cables, it's possible that they could be the main problem (or try purchasing/borrowing a new cable to test with)
  2. Check your TV's settings, such as if it's NTSC or PAL (if the option exists) and it's colors.
If it's not the TV at all, then I'd say it's definitely #1 -- especially if it's a "Mad Katz" cable. Also, be sure that the AV cable is tight into the ports. One last suggestion would be to try a different TV. Hope this helps! Rob
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
2answers
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
3helpful
3answers
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Color problems with 360
It sounds to me like a problem within the 360s hardware itself. You could try sending it back to microsoft or like you said, going out and getting a new one.
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
26helpful
4answers
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
