20 Most Recent
Sony DVP-NS700P DVD Player Questions & Answers
When I turn it on, it flashes "SONY DVD" for a few
DVD player turns Off after few seconds shows problem with power supply board that will be replaced to solve the problem, it happens when main filter capacitors gets leak/ busted.
Please check underneath DVP-NS700, there is hole for manual eject of disc tray, put flat screw driver in that hole and turn it to eject disc tray manually, below image will give you better idea.
Hope this will help.
Thanks.
I get insert disc error on my player. It sounds
More than likely this is an inner system malfuction of the dvd player the owner can try buying and using a cleaning disc for the dvd player, but if that does not correct the problem it is probably beyond his ability to self repair.
Try to play various DVD's and get "insert disc" message .
This could just be a dirty laser lens. Turn the unit on and open tray. While the tray is open unplug the unit without turning off so the tray stays open. Remove the cover and under the disc clamp is the optical pick up assembly. The lens can be cleaned
gently with a alcohol dampened q-tip. The lens should look clear not
hazy. If this does not help the whole pick-up assembly will have to be replaced. There are no adjustments that can be made on these, they are factory set. Go to
www.encompassparts.com and click on guest log in, or
http://servicesales.sel.sony.com (search is in the upper right, make sure to change drop down menu to psrt number) and use this part number A-6062-705-A to get prices.
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Can't read disc
Possibly a bad, or more likely, a damaged disc.
It's not uncommon, especially with often abused rental copies.
Tell Blockbuster - they should give you a credit on the rental.
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
