20 Most Recent Sony PlayStation 2 (PS2) Console Questions & Answers
look my friend the problem of your ps2 is something relationship with the bios, the bios is the program that run at start of your console (without the disc, the navigator menu) this problem is caused because tried to modify your console with some modchip and they do it wrong. Unfortunately your console can't be fixed for you, it has to be some expert in the area (not the guy who try to modify your ps2 of course) in the ps2slim is easy to reapir this things but in ps2 fat is no way back. BLACK SCREEN MEANS DEATH IN SONY CONSOLES, but your console can be fix. I'm from Guatemala.
Mago
Bye:-)
Sony PlayStation... | Answered on Feb 13, 2019
Ps2 Games are DVDrom.
Sony PlayStation... | Answered on Feb 12, 2019
my ps2 it get power it red when i press the reset botten it wont turn to green
Sony PlayStation... | Answered on Feb 05, 2019
If it's an old one, like I have one it will not work online, you have to get a newer version of PS2.
Sony PlayStation... | Answered on Jan 24, 2019
most games require you have a certain amount of mbps (speed of connection) to prevent lagging. a slow connection may be your problem. if you are using a wireless adapter try actually plugging the ethernet cable into the console. also, have you set up your network options and saved them to a memory card?
Advice: go to your nearest pawn shop and buy a new one. They are relatively cheap.
What fell on it, and which part? The disc slot?
Sony PlayStation... | Answered on Jan 17, 2019
try cleaning the laser lens with a laser lens cleaner for video game systems.
or, if you have easy access to the laser lens, use a q-tip dipped in rubbing alcohol (not dripping) to clean it.
gently place the q-tip on the laser lens and gently twirl it.
use other end of q-tip to dry it, gently twirling it.
hope this helps ;p
Sony PlayStation... | Answered on Dec 26, 2018
use a dvd lens cleaner for video game systems or
use a q-tip with rubbing alcohol (not dripping)
gently touch the q-tip to the laser lens.
gently twirl the q-tip.
use other side of q-tip to dry laser lens. again, twirl the q-tip.
hope this helps :D
ps2 goes black and white on plasma tvs
Sony PlayStation... | Answered on Dec 11, 2018
Try
Get All Cars:
Go to Options then Bonus Codes.Enter- XKIMCF Get All Tracks:
Go to Options then Bonus Codes.Enter- TMYTKO
Realistic Damage:
Go to Options then Bonus Codes.Enter- "Damage"
Simulation handling:
Go to Bonus Codes in the Options menu then input "SIM"
To get a blow-off valve:
Type in markskaife at the main screen
Sony PlayStation... | Answered on Nov 30, 2018
You will need software such as Ultramem to make this happen. This forum covers it pretty well:
http://forums.afterdawn.com/thread_view.cfm/512429
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000} I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Hi scorpion013,
PS2 games are region locked which means that disks from other regions won't work on your PS2. If it keeps displaying that message it means that you need to buy the region appropiate disk.
Sorry about the inconvinience.
-Luchen
Sony PlayStation... | Answered on Nov 12, 2018
make sure your console has the ability to read region 1 discs in the first place.
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs.
If you forgot the parental control code and you need to unlock that, though, then try this:
1.Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under
custom setup.
2.When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3.The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4.Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
To change the language settings on a Playstation 2 console, proceed as follows:
1. If there is a game disc in the console, remove it and then power the unit on/off.
2. When the opening screen appears, choose the bottom option of the two. You will see the foreign text, then the time and date beneath it.
NOTE: If you do not see the date, scroll through the options until the date appears.
3. Press UP once to get to the language select option.
4. Press X to select this option, and then select the choice to the right (English) by pressing X.
5. All the text should change to English.
6. Return to the Time and Date Setup and verify or set your time zone.
7. Press CIRCLE to exit the configuration menu.
8. Insert the game disc and navigate to the Browser menu to select the game or browse the memory card.
Sony PlayStation... | Answered on Oct 21, 2018
check to make sure your power cable is securely in, and check for any damage in the cable
Sony PlayStation... | Answered on Sep 05, 2018
You should be able to put the DVD in the tray and should automatically recognize it and go into the movie.
What type of media are you trying to watch. PS2's cannot play blu-ray movies.
Sony PlayStation... | Answered on Jul 05, 2018
Hello Mr .
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Sony PlayStation... | Answered on May 14, 2018
try cleaning your laser with a cotton bud dip in nail remover or any alcohol or any thing that evapourates quickly
Sony PlayStation... | Answered on Feb 24, 2018
Sony PlayStation 2 (PS2) Console Logo
Popular Tags
5,348 questions posted
Top Sony Video Game Consoles & Games Experts
juanmireles1
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
PlayStation Sony
  • PlayStation Sony
Most Popular Question
game runs but game wont come n tv
  • Video Game Consoles & Games
