LG 26LG30 26 in. LCD TV Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
alexander woolfolk
Level 2:
Guru:
  • Expert 276 Answers
  • Posted on Mar 01, 2011
alexander woolfolk
Expert
Level 2:
Guru:
Answers
276
Questions
Helped
110175
Points
753
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Display shows invalid format after connecting computer in LCD tv
The PC video resolution is too high for the monitor to display, you need to set it to the native resolution of the monitor to get the best pictures. Please read here: http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
1helpful
2answers
Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
1helpful
Changed ratio and it went to invalid format now it stays like that. but i can hook it to a normal monitor and it works fine how do I fix this
You PC video resolution is too high for this TV to display, you need to lower the resolution of your PC video card to the native resolution of this TV, 1920 x 1080 @60Hz
7helpful
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
5helpful
2answers
Invalid format??
change the display settings to 1080i or 720p- his tv likely does not support 1080p.
2helpful
"Invalid Format" message
This should help you. I think Chris Duckworth said it best. "sounds to me like your refresh rates or resolution may be set too high on the XP machine."
Go to this website to get the rest about setting up your tv as a monitor. Type invalid in the word search to get to the relevant section.
http://www.inspectmygadget.com/2007/06/11/how-to-connect-your-pc-to-your-television-and-stereo/
Connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
RBG-DTV
The video out resolution through the port may not match what is supported by the TV.
7helpful
2answers
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
