20 Most Recent Olevia LT32HVM 32 in. LCD Television Questions & Answers
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
Olevia LT32HVM... | Answered on Jan 12, 2019
Check the source button on the TV remote is to the correct input!
Olevia LT32HVM... | Answered on Jan 06, 2018
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Olevia LT32HVM... | Answered on Aug 16, 2017
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
Olevia LT32HVM... | Answered on Jul 02, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Olevia LT32HVM... | Answered on Mar 02, 2016
Do a search on Amazon for your Make (GE) and Model #, Universal remote or remote and you should get a list of remotes made for your TV.
...or try several search engines looking, again for Make and Model # but this time add the words, "Universal remote code."
Olevia LT32HVM... | Answered on Jan 11, 2015
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Olevia LT32HVM... | Answered on Nov 23, 2014
It's somewhat skilled work. It will be best to contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to popular brand TVs are given with screen shots of the displays.
Olevia LT32HVM... | Answered on Oct 30, 2014
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Olevia LT32HVM... | Answered on Sep 13, 2014
If the Wii is not powered on at the time you are seeing this. I'd say you have image retention which is burned in images to the panel or CRT if it's a rear projection TV. If its a flat panel TV (Plasma or LCD) you can get a disc like the Disney Wow disc and use the pixel flipper on it. It will flip on and off rapidly the red, green and blue pixels which will age the panel a bit faster, but may even out the retention. Good luck and hope that helps you out :) Here is a link for the Disney Wow disc. Its also to be used for calibrating your TV to get the best images from it. They have beginner and expert modes for calabration
Olevia LT32HVM... | Answered on Jun 06, 2014
Olevia LT32HVM 32 in. LCD Television Logo
380 questions posted
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
olivea tv rc lte remote
  • Televison & Video
