My wii fittness board on the scree keeps saying to start please step off me and press a and nobody is on it and i have put new batteries in and and i dont knwo what to do now
o the wii fit board itself one of the pressure plates is stuck.. This means that it had constant weight on it while you were moving, say for instance you may have put it to the button of a box and put stuff on it.
t you will need to open it up and free the bent contacts on the pressure pads or in between them. Chances are depends on how bad it is you will need to get a new one.
Turn it off and then try again without stepping on it before it asks you to.
Try reconnecting all the remotes.
If you have the board sitting on a thick carpet or something it might cause problems. Try using a hard surface.
Try getting the batteries out and then put them back in.
Try using another game for the Wii board. If it works it's not a hardware problem and you need to get another Wii fit disc.
There also seems to be an issue with rechargeable batteries (the constant charge may be damaging the unit). What you have to do is get a new board from the store you bought it and use AA cells, otherwise the new one might stop working also.
If none of these work your wii board might be faulty (damaged pressure sensors) and you would have to return it and get another one or a refund on your money. Hope this helps!
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
You get off press a wait for it to say step on and then get on. If it keeps saying it after you get off, take out the batteries and get a new battery pack, don't step on it at all until it loads.
