Onkyo DX-C390 6-Disc CD Changer Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I put 2 cd's on top of eachother. now the cd player wont open but it will turn on. when i turn it on it says mechanical error.
Anonymous
Level 2:
Sergeant:
  • Expert 298 Answers
  • Posted on Feb 25, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
298
Questions
Helped
115298
Points
566
You could try gently sliding a thin blade in the top of the tray slot to hold the CDs down whilst, equally gently prising the underside of the tray with a small screwdriver (it may help to press teh open/eject button at the same time).
1helpful
CD jammed in player. Won't open.
Your going to have to take it apart and manually remove the cd.
To do this remove the top cover.
Make sure the power is off and that it is unpluged when doing so.
I have a pioneer cdj 500 cd deck. Havent used it for a while , put cd in, makes a quiet whirring noise as if its about to start turning and then displays error 192. Cd door wont open, help please
You could try to spray some oil into the spindlemotor, sometimes(very rare) they tend to stick a bit and will not turn properly or keep the right speed.
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Why does my vr3 indash say wrong region ?
because. Cd's and DVD's are set for region's if you have 2 that dont match then they wont work with eachother.
-tg
2answers
Error Code E-2
theres 2 screws on top of the unit called teansit screws. remove them, if that isnt the problem then return the pos.
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Cd player wont play
The error code is a mechanical error fault, possibly something in the mechanics that load the CD onto the spindle motor. The only sure way to know what the problem is, is to open the unit and let it load a disc and see what happens. The problem may also be due to a very dirty laser lens, with a dirty lens the laser won't be able to read the TOC (table of contents) and all the CD's will cycle through the changer and a error code will be set. Best of Luck.
4answers
CD player stops, won't open
you have to unscrew the case. then you can get the cds out
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
