Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
IF THE DISK DOES NOT SPIN IT MAY BE A POWER PROBLEM. ALSO MAKE SURE DOOR IF CLOSED. OTHERWISE REPLACE PORTABLE DVD PLAYER. MAKE SURE THAT YOU HAVE IT ON.
On the page your query showed up on, there's a link to www.GoToAssit.com and also a link to http://www.fixya.com/PostQuestion.aspx? Why not give them a try and go from there? Also: www.MintekDvdPlayers.GizmoCafe.com -
Hi Joann, I did a little research. First of all Ebay has 2 different listings.1st is a NON working Mintek MDP-1770 same as your's that has all power adapters including the car charger, but no manual. If you get on Ebay type in this # in the search bar.. 271309709718That is the item # and will sell for $8.99 plus $9.03 S/H. 2nd also on Ebay, is a brand new in the box with ALL extra's and manual for $22.99 plus $14.99 s/h. It is item # 141112619100. Either should work as you would also be getting an extra battery. Good Luck!Michelle
The LED backlight went out. This happened to mine. It's the light that makes the screen bright. If you take it to an electronic repair shop, they should do it for around $30 dollars or so. Good luck!
