Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn Air bottom freezer, french door refrig. Freezer is good, but refrig is not cooling properly. Veggie crisper drawers (closest to bottom/freezer) are cool, but main compartment not. The inside edges of french doors, when opened, are HOT...feels like something is heating that part. Unscrewed light bulbs thinking maybe they were staying on, but same.
Anonymous
Level 3:
  • Jenn-Air Master 43,501 Answers
  • Posted on Feb 24, 2011
Anonymous
Jenn-Air Master
Level 3:
Answers
43501
Questions
0
Helped
10845426
Points
101584
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2helpful
2answers
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
2answers
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
I have a Jenn air side by side refrig/freezer
Hi rdiorio.
you could have one of many faults, either thermostat, compressor or if electronic maybe that have failed. If the Thermostat starts to fail it can produce eratic readings which freezer the chiller part of cabinet, then it can fail completly. What ever you do remember 240 Volts kills. Use a qualified person when dealing with electrics... Cheers
3helpful
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
I have a bottom freezer french door mode. The
remove both crisper pans and check the return are duct opennings. next check if there's a built up frost/ice on the rear wall of the frzr. is you frzr fan blowing air? if so, there's a small window inside the refrig's freshfood side back wall towards the cieling, make sure that's open.the cover should snap off. if window/damper is open, go ahead an pour hot water down the return air ducts behind the crisper pans. they look like grill slots in one or both coners
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Jenn-Air JFC2089HES Bottom freezer, French door:
You have a control board issue and should call out a tech. to do the repair. If your still with in your 1st year of purchase then Whirlpool should pick up the charges of part and labor. The tech. will need to be Whirlpool warrenty certified.
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
