Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IT AS FROZEN - Audio Players & Recorders
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
  • Posted on Feb 23, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
73184
Points
482
Hi,Use the below instruction.
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Tips & Warnings
Take the player to an electronics store if none of the steps above unfreeze the player, as there is likely a serious problem with the MP3 player's hard drive.
Also take out the batteries, if holding the play button for like 5 minutes doesn't work.
Hope that helped.
Have a nice day..
How many grams are in a cup
Assuming yogurt weighs about as much as water, 1 pint of water weighs about 1 pound (16 oz). Two cups to a pint, so one cup weighs about 8 oz.
Frozen cooling system
With a frozen radiator the things that most likely will occur--- split radiator cores ---frozen ,split block---cracked head/s--- broken water pump-- split heater core--burst hoses
Frozen water pump
What is your question, and do you mean frozen as in water frozen or frozen like if the bearing locks up ?
1helpful
Frozen Screen
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
Samsung a707 frozen
Hi friend,
I think first you should check whether the phone or the screen frozen, or both of them are frozen, if the phone is frozen,you may try to turn it off for about ten minutes then turn it on, if it still cannot work, you may try to pull the battery out and then restore factory setting if it needs.If the screen is frozen,it may because.....you can visit our website:
www.1010store.com. Hope this can help you!
2helpful
Some items in freezer are not frozen: bread, cool whip, etc. Meat and veggies ARE frozen. any idea?
This is normal for these particular items. They don't "seem" to be frozen but they are fine. If everything else is frozen that should be, like, ice cream, ice cubes, frozen vegetables, then you don't have a problem. Do make sure your freezer is not building up ice anywhere and that the door is completely shut when you close it.
2answers
My Saamsung M3 YP K5 has frozen and refuses to operate - frozen
im havin the same problem my ones worse when i turn it on its frozen all i can see is white the menu doesnt appear can anyone help me fanks
 Grubhead
Grubhead
SmartAviator
SmartAviator
