Try plugging in an external microphone. If it works, then your internal microphone has failed. If the external microphone also doesn't work, then try reloading the Realtek Audio Driver. There is also the possibility if you have previously used an external microphone, that the jack's connections have become unreliable such that the system thinks that an external microphone is still connected after it has been unplugged. With this situation, plugging an external microphone back in will obviously work.
First of all check in the BIOS that the audio device is enabled. Then, in Device Manager, check that the sound device is properly recognized and it's driver is active - if not you will have to reinstall it. Finally , from the Realtek Control Panel check that the mic socket is correctly identified and active - take the mic out, start Realtek Control Panel, plug the mic and the corresponding icon should light up if all is ok. If it lights up but you still don't have a mic or it doesn't light up at all then the mic is dead , replace it.
If it lights up but it blink it means that it's not recognized so another window will popup, select the mic in it and it should work.
there could be multiple causes of this problem. to fix we need to proceed step by step.
1. try another microphone - try using an external microphone and see if it works. if yes then there could be an issue with the internal hardware of the mic and to fix it you need to contact acer authorised service center.
if an external mic also does not work then please proceed to step 2
2. check the volume settings - go to control panel and then sound and audio devices. click on the audio tab. please ensure that under the sound recording section the audio driver(for acer aspire realtek mostly) should be selected.
3. go to device manager and reinstall the audio drivers.
4. if this is a recent problem that has been reported then please perform a system restore to a backdate when the mic issue was not there.
please let me know if any of this helps else we can check out further options.
Nope you can still use Volume Control while Using
Realtek High Defnition Audio. i'm using
Realtek High Defnition Audio too and Volume Control work find to me on any OS installed on my computer
in device manager right click your realtek driver and update
then in control panel realtek hd audio open click mixer and
you will see mic volume and stereo mix
click on the dot under mic it will turn yellow
then click on the wrench icon and check both boxes
restart pc and please let me know if this fixed ya
if not then we'll need to check some other settings.
I have the same pc and i have no probs at all
To test the microphone, click "start" button, then "Control Panel", then "Sounds and Audio Devices". On the popup window that opens, click on the "Voice" tab, then click on the button that says "Test Hardware". After several seconds this will bring up a test program that will show a noise level meter when you're speaking into the microphone. (The default device listed under voice recording should be "Realtek HD Audio Input".)
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
First thing is first, there should be 3 audio jack inputs. Line in, Line out and Mic. Make sure you are plugged into the Mic input.
Next if you are running windows XP check to make sure the Microphone volume is not muted and turned up. Do this by going to control panel --> Sound and Audio Devices --> volume tab --> Advanced button. The Microphone volume should be there if not select file --> properties and make sure microphone is checked. It should then appear on the volume controls.
This should take care of it if not what program are you using the mic with?
But my mic is supposed to be inbuilt
