Cellular Innovations HFBLUH1 Bluetooth Headset Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
  • Posted on Feb 23, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
73184
Points
482
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Cellular Inn... Master 1,001 Answers
  • Posted on Nov 26, 2016
wwlvictoria
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603957
Points
6027
  • Universal Bluetooth headset for Apple iPhone 6/5s/5c/5, iPhone 4s/4, Samsung Galaxy S5/S4/S3, PC Laptop, and other bluetooth device;
  • Deep Sleep mode extends battery life;
Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless... Charm Sonic Welcome to Charm sonic
How do you pair with blackberry 9700
Once you make your Blackberry discoverable, then put the Plantronics M100 headset into pairing mode by holding the call control button until the headset flashes red and blue. Below is the link below for the M100 user guide with the pairing instructions.
M110 User's Guide
Good luck from Headsets Direct!
1helpful
Can't get new Blackberry 9630 to discover Plantronics 330. I've followed the pairing instructions for both instruments, but the Blackberry doesn't detect the headset no matter how close it is.
Once you make your BlackBerry discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320 User's Guide
6helpful
2answers
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Morotola H300 with Blackberry Device
re-pair and add to trusted devices be sure to use 0000 for passkey
USER GUIDE
1helpful
Need to connect jabra bt135 to blackberry mobile phone
Here's the link for the user guide:
http://bit.ly/bW8Kyw
It will tell you how to set it for discovery mode to pair with your Blackberry. And, remember to bookmark the page.
If I remember correctly, on your phone, go to settings > connections > bluetooth (turn on) and select discovery mode to pair your headset.
The user guide for your headset is in PDF Format so it may take a minute for the page to load. If you need a PDF Reader to view it you can download Adobe Reader for free:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
7helpful
4answers
I can not receive incomming blue tooth on my blackberry 9500
from :http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB05409
[email protected]
Top Cellular Innovations Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
